Old 09-21-2007, 08:04 AM
jeff5347 jeff5347 is offline
Default what power steering pump can i use
Hey guys, im looking to retire the old saginaw PS pump that i have (came off a 78 malibu) and install a late model pump with a remote resevoir. I dissasembled the pump tonight and pulled it out of the saginaw body. My setup right now is the factory 68 camaro steering box but over the winter ill be doing the 3rd gen conversion. I just need to make sure the pump i use wont cause any problems. Am i able to use this pump and run a remote resevoir instead of buying a new pump?
If so, how would i do this?
If not would one of these work, Could i take of the factory clip on resevoir and have a remote resevoir?? Im on a tight budget so making something work by fabbing is not a problem. All help is definately appreciated.
http://cgi.ebay.com/ebaymotors/GM-PO...spagenameZWDVW
could i use this one and use a remote resevoir instead?
http://cgi.ebay.com/ebaymotors/GM-3-...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/NOS-P...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/GM-Po...spagenameZWDVW
I know i threw a lot on here. If these arent good canddiates what do you recommend.
Thanks Jeff
