Old 12-07-2004, 10:56 AM
LIL QIK LIL QIK is offline
Default Tire Size Question
I apologize if this is out there somewhere but I couldn't find it.
I need help on what the largest tire is that will fit on a factory stance 68 SS 396 car. If you could please provide the height and width.......also will a 15x10 fit back there and if so what's the backspace needed to do so. Also need recommendations on what the backspace is if I use a 15x5 on the front.
Thanks for any help offered..........but I'm new to the first gen scene. :o
1968 Camaro SS
Twin Turbo 383
Old 12-07-2004, 11:04 AM
camcojb camcojb is offline
15X8" with 5" b.s. and 275/60-15 is the largest we could fit on a friends 69 without rubbing. A 10" wheel will physically fit but the tire will rub unless the car sits up in the rear and is never allowed to come down.
Old 12-07-2004, 12:19 PM
MaxHarvard's Avatar
i have 17x9.5 with 4.5 BS with 275/40
it fits really well... See pic below.
I'm pretty sure Jody is right, if you want a 15x10.
Old 12-07-2004, 12:32 PM
Most the guys here run 17/18's. You can run a 9.5" wide wheel with those because the sidewall on the tire is much narrower as compared to the bulge that a 15" tire has. If you're aiming at handling I'd consider the 17/18's over the 15's
Old 12-07-2004, 12:36 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Eric remind him of the lower shock plate issue that you had just in case...
Jim
Old 12-07-2004, 12:42 PM
I am planning on running some 18's later but not until I can get the mini tub kit...........until then I'm gonna just make it look like a hot rod with some decent meats in the back and somewhat skinny on the front........more or less like a straight line car..........
Once I have the mini tub, I'll lower it and put the wheels that I want on it.
1968 Camaro SS
Twin Turbo 383
Old 12-07-2004, 03:35 PM
rwhite692's Avatar
The 67-8 cars are a little more forgiving, on the outside, than our 69s due to the round wheelwells (less likely to have contact at the top of the wheel opening...)
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 12-08-2004, 06:33 AM
MaxHarvard's Avatar
haha, ahhhhh yes... those were the days huh?
If you are running monoleaf springs... big tires wont work... period.
You will need multileaf springs and multileaf perches. Works like a charm
Old 12-08-2004, 07:56 AM
Well I'll consider myself lucky for once..........it's got the multileaf in it.
1968 Camaro SS
Twin Turbo 383
Old 12-08-2004, 08:13 AM
Ricochet's Avatar
Ricochet Ricochet is offline
The combo I had on my 68 was a 15x8 (5" backspace) with a 275/60-15. It was the biggest I could put in there and get the car to sit right. I ran 15x6(3.5" backspace) up front with 215/60-15.
I had to show this one!!
