Old 09-22-2007, 12:38 PM
retcpo96 retcpo96 is offline
Default Help with 84 Mustang
Good Afternoon, I am looking for info/help on an 84 mustang we are doing in memory of my son who passed away in february of this year. He always wanted to put an 351W turbo charged in his car. ... So far, I am thinking about tubular cross member, tubular a arms and coil over springs up front. The 351W block is at the machine shop. putting a 9 inch ford rear end it the car. Not really sure what to put into the 351 internals and what brand of turbo-kit to buy. Also, not sure about the rear suspension yet. Anyone with ideas or has done something like this before, your assistance will be greatly appreciated. My son Ian eventually wanted to run his mustang at Targa Newfoundland.
Old 09-22-2007, 01:09 PM
Porterbuilt Porterbuilt is offline
Terribly sorry to hear about your loss. What a great way to help keep the memory of your son alive! Sounds like he had some good plans for the build.
I don't have any input for you, but wanted to welcome you to the board and wish you good luck on the project. I am sure you will receive lots of helpful recommendations here.
Old 09-22-2007, 11:42 PM
ntchbl67 ntchbl67 is offline
Sorry to hear that about your son.
Do you want to make it a stroker motor? Either way just go ahead and put a forged rotating assembly and low compression forged pistons. The cam and heads are very important also so have a custom grind cam made specifically for your application and some good flowing heads like AFR's or something. For the front suspension you can just install a tubular K-member with tubular A-arms and some good struts. For the rear you could replace your upper and lower control arms with some adjustable ones and maybe coil-overs or trick springs.
Old 09-23-2007, 12:15 AM
tyoneal's Avatar
tyoneal tyoneal is offline
retcpo96:
Click on the links off this site for people who build engines. They are extremely talented builders, many of whom specialize in Turbo Charged Engines.
They will be able to answer all your questions and if you were open to it, they could probably build the entire engine. All you would have to do is pick it up. (And write a check)
Check them out and let us know if they were helpful.
Here are a couple to get you started:
http://www.schwartzperformance.com/
http://www.nelsonracingengines.com/
http://www.mizfitmotorsports.com/index.html
http://www.stenodperformance.com/main.html
http://www.goodies-speedshop.com/
Good luck and I'm sorry for your loss.
Best Regards,
Ty O'neal
Old 09-23-2007, 06:52 AM
krptonite's Avatar
krptonite krptonite is offline
Hi, another good source for anything mustang related is seanhylandmotorsports.com.
Old 09-23-2007, 10:20 AM
ZVT's Avatar
ZVT ZVT is offline
Sorry to hear about your son.
Check out http://www.turbomustangs.com/
That will be one of the best resources you can find as far as turbo combo's in a fox body mustang.
I know of a couple people in the forums that have or are running a siilar setup that you want to build.
Zee
ZVTDESIGNS-AUTOMOTIVE ARTIST AND VEHICLE DESIGN
[SIGPIC]https://lateral-g.net/forums/image.php4?type=sigpic&userid=4368&dateline=121287 1168[/SIGPIC]
RENDERING GALLERY!!
Old 09-24-2007, 11:08 AM
Default Thanks
Thanks guys for all the information. I appreciate it more than you can know. I'll keep everyone updated. Again, thanks for all the information.
Old 09-24-2007, 02:23 PM
sorry to hear about your son im sure its hard to lose a child.have any idea on what you want to do to the mustang show car drag car road racer.its a fox body the sky and your wallet are the limits of what you can do.
Old 10-03-2007, 06:54 AM
deuce_454's Avatar
sorry to hear about your loss, no parrent should loose a child, wih that said i like and respect that you have decided to build somthing for him. it is nice to have somthing tangible with which to remember him, or just be able to the memory of him for a sunday drive..
my thoughts go out to you, and i wish you wellcome onboard.
With regards to the build my best advice is to set a goal and follow it.. working with an artist gives you somthing to aim for, especially since its a dedicated build, and it also keeps you from shifting drrrection mid-build which by the way is the dumbest and fastest way of wasting money (and ive done it every time..).. since youve chosen to post here on Lateral-G.. does that mean you are building a pro touring style mustang?? or are the turbos just to scare the passengers?
Jake: Hit it.
