Old 09-22-2007, 03:24 PM
Bad94 Bad94 is offline
Default Torque Arm Help
Im looking at doing a torque arms set up on my 94 S-10. The truck has a 60/40 weight ratio. The bottom of the frame is 5" off the ground at ride height. The wheel base is 108".
The longest i can make the lower links are 26"
What is the shortest i could go?
How long do i want the torque arm itself?
How high off the ground do i want it mounted?
I will be building everything adjustable. But i just need help getting it close.
Also i will be running coil overs.
I would do a 3 link but i dont want to cut the bed.
Any help would be great.
Thanks Dan
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 09-23-2007, 01:07 AM
try downloading the performance trends software trial version, i think it still has a 9 day trial, and you should be able to figure out a design in that timeframe.
i have a lowered lightning, which is getting a 3 link, without cutting the bed. not quite as low as your S10, but i would think you could probably get away with it, unless its got a c notch.
Old 09-23-2007, 03:29 AM
if you use 2 links then a torque arm its a 3 link also think about a watts link they work great.
Old 09-23-2007, 07:19 AM
I just downloaded that and its only the front suspension.
And yea my truck is lot lower then ur will be. my top of the pumpkin is about 2" off the bed floor, and i have a c notch.
Old 09-23-2007, 01:06 PM
the newest version has full vehicle as an option, you can choose to analyze the front, rear, or all 4 corners at once.
you might poke around over at corner-carvers... they have a section on custom suspension builds.
Old 09-24-2007, 09:53 AM
David Pozzi's Avatar
You have to select Advanced in the menu then turn on the rear suspension function.
http://www.PozziRacing.com
Old 09-24-2007, 04:38 PM
I dont see a advanced tab.
Old 09-25-2007, 11:47 AM
Mean 69 Mean 69 is offline
While throwing numbers at one of the better suspension programs is a good way to model things out, I think a better initial approach is to read up on the physics of what the numbers mean in one of the really good books out there. Herb Adams "Chassis Engineering" is a good one, as is the Milliken's "Race Car Vehicle Dynamics," with the latter being a bit more on the text book, dry reading end of things, but with a HUGE amount of very useful information. "What" you are trying to achieve and what you are willing to compromise is very important in any suspension system, especially so in a T/A arrangement.
Just a couple small points, the additional links (i.e. the locating links, not the T/A itself) are less of an issue in terms of making them as long as possible in a T/A setup than they are in a more traditional three or four link setup. 26" in my opinion is plenty long, even shorter is shown to work very well in other T/A applications.
As for the length of the T/A itself, this is where the fun engineering trade-offs will really show in this setup, and is probably the most important decision that needs to be made on a T/A setup. One one hand, keeping it physically short will help anti-squat for forward bite off the line and out of corners. That's a good thing, as the rear weight bias is low in your application, you'll want all the help you can get. But, the very real downside to this is that along with the lighter rear weight (relative), a shorter arm will increase the potential for rear brake hop, both things are working against you (longitudinal weight transfer forward under braking to an already nose heavy truck, and the downside of a short Side View Swing Arm's influence on this factor). I'd be very wary of this if it were my own project, solid braking performance to me is a LOT more important than forward bite, it's a survival instinct thing.
SO, that might argue that a longer arm would be preferable. But now you have the physics of creating a stiff enough Torque Arm to handle the same amount of rear wheel torque, but with a far longer bending moment, which means it needs to be very stiff in bending. Lower anti-squat resulting from such an approach is interesting, and not ideal, but you have to pick your battles.
The behavior of a Torque Arm application is dominated by the physical arm length itself, obviously things like spring rates, damping, etc are all important factors, but there is only so much tuning around the physical package that you can do. I state this because you noted that you'll make it all adjustable, which is perfect, but the biggest thing you'd probably want to play around with is the length of the T/A itself, and that is pretty much impossible without making several arms and the frame structure to mount the forward pivot(s).
T/A's are awesome, but you really need to have a very good idea of the basic performance goals and understand the trade-offs in order to make a good initial decision. This is one of the important distinctions between a 3-Link (or four link) and a T/A, besides how the torque loads are reacted back into the vehicle, it is a lot easier to build a tunable system using a true link approach. As you pointed out though, it's somewhat more convenient to package a T/A in many cases than a good 3-Link, which is why you see the T/A's on many of the aftermarket suspension supplier's list of products.
Great project, keep us posted on it all so we can all learn from your efforts!
Mark
Old 09-27-2007, 09:21 PM
first, be sure you downloaded the "full vehicle" version.
Look under "Help" on the right, then one of the selections is something like "Advanced" or "Full" That will allow you to run rear suspensions. Then on the main window to the right of the animation, there will appear a button for Front and one for Rear.
Look at some of the examples the program comes with. Load one that has front and rear data and then modify that file with your dimensions.
My full version doesn't have a torque arm option however.
David
