Old 09-26-2007, 01:56 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Default Raised Intake Ports?
Can someone explain cylinder heads with raised intake ports, their benefits and what type of intake manifolds are required to run these types of heads. Thanks in advance.
-Brian
Old 09-26-2007, 02:46 PM
QSPres QSPres is offline
Banned
The higher the intake port, the less of a bend there is going into the cylinder. Anytime you can lessen the transition between the valve seat and combustion chamber/cylinder, you'll get more airlfow and less tumble.
That's a simplification of it anyway...
Intake selection will vary. Some heads/marques have matching intakes, some require welding and grinding of existing intakes, some require sheetmetal intakes.
Old 09-26-2007, 03:22 PM
70TWO NOVA's Avatar
I just puchased a set of raised intake port heads and was just doing some homework on what good intakes work with them. I have a Edelbrock Performer RPM and some people say it will work with the heads and some say it wont.
Old 09-26-2007, 04:07 PM
DAWG's Avatar
DAWG DAWG is offline
itll work but needs some blending and port matching.
but better off with a victor intake or similar
SIT DOWN _SHUT UP_HANG ON
Old 09-26-2007, 04:16 PM
70TWO NOVA's Avatar
Thanks for the help guys, I really appreciate it.
