Old 09-26-2007, 03:47 PM
mhotel1 mhotel1 is offline
Default 4th gen brake rotor help
I am putting 4th gen rotors and calipers on a 69 Camaro with drum spindles. everything seems to line up fine with the bracket i have after turning the hubs down but i have 1 concern: The bolt holes in the newer rotors are much larger than the stock 7/16 wheel std size and the rotor seems to be to lose on the hub. The holes in the rotor are even bigger than 4th gen studs(12mm ~.480)...My question is will this be to lose? do i need to drill out for bigger studs? it just looks screwy
69 Camaro, LS1, T56- Corn is for making bourbon
Old 09-26-2007, 08:52 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
I dod the exact same thing on my 1972 Nova heres some pics: (i used arp studs in my hubs, but I do run spacers for my wheels)
Old 09-28-2007, 05:49 PM
I am assuming the extra size of the holes in the rotors does not matter once you tighten down the lugs. I have talked with 2 others and seem to have no problems.
...Thanks for the reply...the Nova looks damn good!
Old 09-29-2007, 10:40 AM
70TWO NOVA's Avatar
thanks, i also have not had any problems once i tightened them down.
