Old 10-02-2007, 12:40 PM
BAP BAP is offline
Default For Sale: Mustang steering, suspension, Chris Alston Parts
These parts were ordered from Total Control Products/Chris Alston Chassisworks – (www.totalcontrolproducts.com) for a 1964-1966 mustang. They may fit same year model Comets, Falcons, Cyclones, and Rancheros. All of the parts are brand new and most are still in their original sealed boxes.
The total cost of the parts was $14,960.04. We will fax/email you a copy of the invoice if requested. The owner of the project vehicle stopped because of personal reasons (divorce). Our loss is your gain, as these parts can be purchased at a fraction of the cost. The price for this package is $9,000.00 FIRM.
- Front Ford coil over conversion with upper and lower control arms, strut rods, upper and lower coil-over mounts, coil-over shocks and springs and spindles.
www.totalcontrolproducts.com/download/datasheets/FCOC_DS_WEB.pdf
- Power rack and pinion with tie rods. Flaming River tilt steering column with floor mount, dash mount shim, female wire loom adapter, horn relay. Also includes a steering shaft and u-joint installation kit. www.totalcontrolproducts.com/download/datasheets/RCK_DS_WEB.pdf
http://www.totalcontrolproducts.com/...3-COLM-10.pdf\
- Power steering pump, aluminum fluid reservoirs, braided power steering hoses, and mount bracket set for 260, 289, or a 302 engine. www.totalcontrolproducts.com/download/datasheets/PSP_DS_WEB.pdf
- Rear pushrod suspension with watts link. Includes trailing arms, torque arms, center support driveshaft loop, subframe connectors and hardware. www.totalcontrolproducts.com/download/instructions/7903-RPSS-FD.pdf
- FAB 9 rear differential housing. STRANGE 31 spline axles, STRANGE S series iron case posi-unit differential with 3.70 gears. www.strangeengineering.net/catalog/pdf/045.pdf
- Wilwood front disc brakes, with 11.75” diameter slotted, drilled, and zinc washed vented rotors. 4 piston dynalite calipers. Front hubs are included. www.wilwood.com/PDF/ds505.pdf
- Wilwood rear disc brakes with 12.19” diameter drilled, slotted, and zinc washed vented rotors. 4 piston dynalite calipers. Rear brakes are equipped with parking brakes.
www.wilwood.com/PDF/ds420.pdf
- Wilwood master cylinder www.wilwood.com/PDF/fl153.pdf.
- Wilwood proportioning valve. www.wilwood.com/PDF/ds488.pdf
This are special ordered and/or custom made parts. Parts can not be returned.
EMAIL: [email protected]
Old 10-02-2007, 02:31 PM
deuce_454's Avatar
what fraction?? could be interesting as i will need it in the future, so if the price is right
Jake: Hit it.
Old 10-03-2007, 05:15 AM
BAP BAP is offline
Sorry I fixed the price this morning. The price for this package is $9,000.00 FIRM.
