Old 06-09-2005, 07:38 PM
nvawgn's Avatar
nvawgn nvawgn is offline
Default let's play pin the tail on the drive shaft!
had a little problem on my way to pic up the wife from work,
Old 06-09-2005, 11:02 PM
907rs's Avatar
907rs 907rs is offline
OUCH!!! How'd you do that?
Bill
Old 06-10-2005, 05:01 AM
69rs's Avatar
69rs 69rs is offline
That's hardly ever a good sign.
Old 06-10-2005, 08:05 AM
nvawgn's Avatar
that my friends is what happens when to much horse power meets a worn rear u-joint getting on the freeway at 75 KABLUEY!!!! oh my goodness what a sound, scared the poop out of me , 2k on the new tranny and now time for a new one, driveshaft is gone and the engine sounds funny now
Old 06-10-2005, 10:21 AM
69boo307 69boo307 is offline
I've seen alot of twisted driveshafts, but I've never seen a tailhousing break off like that!
Old 06-10-2005, 10:35 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Good thing your car didn't make like a pole vaulter.....Bad juju can happen when it breaks off at that end...glad you are OK.
Old 06-10-2005, 12:24 PM
trapin's Avatar
trapin trapin is offline
That's where a drive shaft loop becomes invaluable.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 06-10-2005, 08:15 PM
68BNUT 68BNUT is offline
Just one question? Did you change your shorts before or after you finally picked your wife up!!
68 Camaro SS
Justin
Old 06-10-2005, 08:23 PM
Steve1968LS2's Avatar
A little JB Weld and that will be as good as new!!
Actually.. that is pretty crazy.. you would think there would be weaker places for a break to happen.. must of been cracked to begin with or something..
As said, glad it didn't go worse for you (pole vault)
Old 06-10-2005, 10:47 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Will an H-pipe/X-pipe exhaust function as a driveshaft loop in this case? I've wondered about this since I didn't make a provision for a loop...
-Tom
camarorestoration.com
