Old 10-09-2007, 12:33 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default LS1/AC factory Sub Frame?
I know this has been talked about but I'm a little confused. If I get a LS1 motor with AC, can I use the factor belt set up? I want the AC ,so do I need to notch the frame? or is there another way to make it fit.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 10-09-2007, 01:03 PM
camcojb camcojb is offline
I believe you either notch the frame or build a custom mount like Mark Stielow did. ATS was supposed to have or be coming out with this bracket to allow the low a/c without frame mods.
Old 10-09-2007, 01:07 PM
bigtyme1's Avatar
Which car of Marks? The white one is running the LS7, I think it's the same but not sure.
69 RS Ragtop
[email protected]
Old 10-11-2007, 11:49 AM
yes, Camaro X, the white one. I believe his mod would work for all the LSX engines.
Old 10-12-2007, 06:50 AM
bigtyme1's Avatar
I called ATS and what they did was creat a whole belt system with the AC on top. It looks like a great system but not in my budget write now. I may just go with out AC for now until I can afford it. I'm just thinking for the price I could just get a new sub frame. If you got any more Idea's lets get togethor. See you at SEMA.
69 RS Ragtop
[email protected]
Old 10-12-2007, 07:49 AM
they must have dropped the modded a/c bracket deal then, at one time they were going to offer it. Their front drive is first class.
