Old 10-12-2007, 07:14 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default Where to buy big brakes for 2nd Gen F body
Trying to find some killer bolt on big brakes for a 76 Trans am.
Right now the car has drum on the rear and would need a conversion.
Who/what/where??????
Old 10-12-2007, 07:46 AM
jy211's Avatar
jy211 jy211 is offline
my suggestion....www.gpsuperstore.com
Frank of Prodigy Customs runs it....I believe....
Old 10-12-2007, 07:49 AM
Yup, give me a call and we can see how big you want to go
Frank Serafine
Old 10-12-2007, 09:47 AM
As an alternative, we're running a sale on Baer Brakes right now, that will save you 10-15% off of retail, and the nice thing about Baer is they will provide everything you need to do the install. They have kits ranging from their 13" Track system, all they way up to their six piston mono block caliper, and 14" rotor, like what we are using on our 67 Chevelle:
Old 10-12-2007, 10:02 AM
jy211's Avatar
Whoa...what color is that on the frame?
Old 10-12-2007, 10:52 AM
69MyWay's Avatar
Frank - can I be lazy and have you pm me on what a system using no larger than 13" up front and whatever matches in the rear as a bolt on to this disc/drum 76 t/a - part number, price---etc?????
Need something large - plenty of "bling" and zero hassles in bolting it up.
Old 10-12-2007, 11:17 AM
You have the option of 12.2 Dynalite 4 piston rear or 13" Superlite 4 piston rear, both rear set ups use the awesome internal e brake. Using a 13" six piston front, you will spend between $2900 (12.2" rear) and $3700 (13" rear) for a total car brake package including E brake cables, braided front and rear hoses, Power Booster, master cylinder, distribution valve, Prop valve, Wilwood high temp Dot 4 brake Fluid, we even include the safety wire and safety wire pliers you need to assemble the 2 piece rotors.
Frank Serafine
