Old 10-15-2007, 02:38 PM
Fluid Power's Avatar
Default Aluminum Cleaner
In Hot Rod or Car Craft there was a little article about a cleaner that was used to clean aluminum manifolds etc.
If I remember correctly, it was an aerosol spray that you sprayed on and hosed off. Anybody remember what the product was?
Darren
Old 10-15-2007, 03:35 PM
4mm 4mm is offline
I saw this one in either PHR or Street Machines, I can't remember, but I saved it just in case I needed it in the future.
http://www.metalwax.com/METAL%20CLEANER.htm
Old 10-16-2007, 02:01 AM
ntchbl67 ntchbl67 is offline
Darren
I have used a cleaner used for window unit A/C's. You can buy it at any hardware store. I don't remember the name but you won't miss it cause it is PINK. They sell it in a spray gun or in a whole gallon. Just ask anybody at the hardware store and they will know what you are talking about. It has worked wonders for me..........just spray it on and then rinse after a while.
