Old 10-18-2007, 04:11 AM
DB Z28 DB Z28 is offline
Default Need a New Job starting about $32.58
Milwaukee Skilled Trades Job Opportunities:
Experimental Machinist/Fabricator "A" (see qualifications below)
REQUIRED
Eight (8) years minimum as a prototype machinist, fabricator or an apprenticeship in a related field where experience and skill would apply to this position. Minimum of 20 verifiable credits in related trade school training or coursework that would enhance the skills required for this position. Ability to successfully complete the Trades Group Skills Assessment Battery. Previously demonstrated good problem solving skills, demonstrated basic skills including, but not limited to: reading comprehension, mathematics, spatial relations, troubleshooting and trades knowledge. Must have the ability to complete a job from start to finish, which includes: the ability to interpret complex engineering drawings and sketches, the ability to work from verbal instructions for design intent, work with minimal instructions, work with CAD models, develop work holding methods, ability to generate complex cutter paths utilizing CAM software and select the necessary tools to produce prototype parts and assemblies ranging from simple to complex that have a professional appearance and accuracy. Ability to adequately communicate verbal, written and comprehensive skills with others. The employee must be able to generate their own ideas regarding designs and method of accomplishing desired results. Must have mechanical ability and basic mechanic skills, but need not be a motorcycle mechanic. Demonstrated competence in the fabrication and welding of critical assemblies where strength, distortion and other factors must be considered. High level of skill to produce or modify complex, close tolerance parts is essential using a variety of equipment. Demonstrated on the job proficiency of CAD/CAM, preferably SurfCam, ProE, ProNC, Vericut, Predator, Delcam PowerMill software. Must have the ability to create and edit G-code. Must have ability to set-up and operate several of the following pieces of equipment: CNC milling machines, CNC lathes, tubing bender, water jet, and press brake. Basic computer skills, such as Word, Excel, Outlook, etc. Ability to demonstrate above skills in a practical exercise may be required. Some travel may be required to support engineers, for training purposes or to complete work assignments at remote locations.
Preferred
Produce composite lay-ups.
Operate rapid prototype equipment.
Applicants must be SHIFT AND LOCATION FLEXIBLE. If interested, please submit a cover letter and resume to:
Harley-Davidson Motor Company
PDC Human Resources
Job Code: EXPMACFAB1007
11800 W. Capitol Drive
Wauwatosa , WI 53222
Questions? Contact Sukari Sanford at 465-6164 or Deb DeRosier at 465-6014, Product Development Center-Human Resources.
