Old 10-18-2007, 06:06 AM
Default An fittings to T56 hydraulic clutch
Have you seen these ?
http://carshop.carshopinc.com/produc...ssell%20640281
Could these be used as an alternative for drill mode ?
63 Z06
Old 10-25-2007, 08:31 AM
Silver69Camaro Silver69Camaro is offline
Wish that was available when I did mine. I needed the quick-connect fitting that goes directly into the throwout bearing, but I ended up using the stock braided line and installed my own teflon -4 fitting.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
