Old 10-19-2007, 03:31 PM
eddiek eddiek is offline
Default 66 Nova info needed
Who makes the best front and rear clip for a 66 Nova. I'm looking to build a pro touring type of car and just not sure. Thanks for the help.
Old 10-19-2007, 05:33 PM
krptonite's Avatar
krptonite krptonite is offline
hi, chris alston does a nice front clip, i think they are also doing a rear 4 link conversion, www.cachassisworks.com also heidts do a similar front end, they also do an independent rear end as long as you dont want to put too much power thru it! and fatman fabrications do these products too. not sure which is best but i am sure someone will post if there is a problem with any of these setups.
Old 10-19-2007, 08:15 PM
novanutcase's Avatar
Chris Alston makes, IMO, the best bolt on but keep in mind that you are restricted to the ride height the have on the clip unless you airbag the car.
Are you building a cruiser or a track car or both?
If you want to go custom and be able to dictate your ride height and suspension components then there's no one better than Ironworks for that! Check out my build and you'll see why I say that!
John
Old 10-19-2007, 08:38 PM
Sales@Dutchboys's Avatar
I did a crap load of research before I picked CA Chassisworks.
It ended up being a little more money then the others but its by far the best out of all the other clips. very easy to install. If you have any ?s about installation just drop me a PM and I will give you my Phone number and we can talk!
Also by far the best looking of them all as well.........I loved the down bars....
dutchboyshotrods.com
269-823-2967
