Old 10-20-2007, 01:50 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Cooling Problem, can you help?
Hey lat-g,
I think I have a cooling issue. I have a 396 BB with a high flow alum water pump, alum summit brand radiator with a single 16" elec fan and I blocked off the hose that goes from intake to water pump(I have no idea why I did that). I have only driven the car a few times but here is whats going on......
just driving accross town she gets over 210 degrees. I drove it home and two blocks from my house, I looked at the gauge and it was very very close to 250. I turned it off and it started to blow coolent out the over flow. It dose that almost every time i drive it or start it for longer then 10 min. I thought maybe the thermostat was stuck so I pulled it out and cut the guts out of it and put it back in. Drove it all around town and the temp was holding under or arround 210. I bought a over flow tank and when I drive it that hose (overflow tank hose) gets rock hard. I have a 8 lbs cap on the radiator...
Is that normal?
Could it be the high flow water pump and get a stock one?
Do I need the hose that connects the intake and water pump?
Thanks for your time,
-Brian
WicKeD
Old 10-20-2007, 02:36 PM
camcojb camcojb is offline
What temp does it run at a steady 40-50 mph or higher? Is it heating up when you get slow or idle, or the same everywhere?
I've never seen an 16" electric fan that would properly cool your combo at idle and low speeds.
Old 10-20-2007, 03:29 PM
WicKeD_SS's Avatar
I havent had it up to 40 - 50 mph. Didnt want to go to far away with the it over heating. Hmmm maybe the 16" is too small then? What should I get??
Still not sure why the over flow hose is getting hard and it over spilling to the overflow so much. any ideas?
Thanks!
WicKeD
Old 10-20-2007, 04:49 PM
Thanks!
8 psi cap is too low, which is likely why you are pressurizing the overflow. I've had great luck with the Lincoln Mark VIII fan, cools over 1000 HP without issue. Puts out probably 3 times the airflow of your 16" fan. Dual Spals also work pretty well, though I lean to the Mark VIII.
Old 10-20-2007, 07:17 PM
Ruslow Ruslow is offline
That hose you blocked off is the bypass hose its purpose [or atleast one of them ] is to keep the water[coolant] from dead heading against the thremostat.look at the t-stat it opens in towards the motor with the hose blocked off the water builds up against the t-stat and will not let it open.you can either run a t-stat with 3 1/8 holes drilled in it to releive some water psi or do like you did and remove the guts.BUT you have to have some back psi in the system to help eliminate air pockets and bubbles.As for temps each motor will seek its on temps the majority of mine run rite at 190 and that is running hard[wot for miles].another thing to llok at is were you have the sender?it HAS to be in coolant FLOW not just in a touching coolant.[Fixed one of those about 3 weeks ago]Stan
Old 10-20-2007, 08:21 PM
69bird 69bird is offline
I'd get a high flow thermostat if you don't already have one. I use a mark VIII fan and it works great. You can find them pretty cheap on ebay.
Old 10-22-2007, 08:06 PM
WicKeD_SS's Avatar
Thanks guys for the help, ill try getting a mark VIII fan to start. What PSI cap should I run?? I Will also put the bypass hose back in. I have the temp gauge in the top of the intake, is that where It needs to be?
I knew Lat-g would come threw!
WicKeD
Old 10-22-2007, 09:02 PM
TravisB TravisB is offline
upper intake temps are usually higher than temps in the head. We try to put them in the head when we can.....
Kenny Davis Hot Rods
Old 10-23-2007, 03:13 AM
COYBILT's Avatar
COYBILT COYBILT is offline
I would advise on atleast a 12 PSI cap, I run a 14PSI cap on my jaguar and with the dual spal fans it never goes above 190. Try a milodon high flow thermostat and a high pressure cap should help cure some of the problem.
If that dosent work I Also would adivse in buying a flow Kooler water pump.
They really do work, How do I know this I own a pontiac and there know for getting hot.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 10-23-2007, 07:05 AM
TopEndeR TopEndeR is offline
Me and all my buddy's with small blocks and big blocks run a 3.8L V6 Taurus fan that pulls an estimated 2000cfm. Junk Yard for $25 Work's great!
