Old 10-20-2007, 06:30 PM
mstennes mstennes is offline
Default Lateral Dynamics suspension question
I'm just about to pull the trigger on a Lateral Dynamics rear suspension fr my 69 Camaro. My question problem is the rear seat area. Does anyone have pictures of the rear seat area completed with new rear seats?
Thanks,
Mike
Old 10-20-2007, 07:10 PM
Steve1968LS2's Avatar
No, I decided NOT to run rear seats since I have a cage. I can shoot you pics of the area effected by the third link. It shouldn't be tough to design a rear seat to fit the area.
Get me your email address.
Old 10-21-2007, 09:47 AM
James OLC's Avatar
We thought about running a rear seat and even had a mockup done at one point using third gen rears but with the cage decided not to use it. There's lots of room to do it - the biggest difficulty came with the seat back because the Camaro is so short compared to most 'easy' donors.
To give you an idea (no seat):
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 10-21-2007, 11:23 AM
I guess I should add in here, my 69 is a convertable so I need to retain my rear seat. I'm doing a bar that will still allow the use of the rear seat. Still being a vert I need the rear seat of some sort.
Thanks,
Mike
Old 10-21-2007, 11:41 AM
68protouring454's Avatar
4th gen camaro rear seats should work out of the box,
jake
Jake's Rod Shop
Old 01-12-2008, 10:45 AM
TT LS2 TT LS2 is offline
jake
Any pics or references showing this installed?
Old 01-27-2008, 10:07 AM
James OLC's Avatar
Here are a couple of shots that I had kicking around from when we we playing with some junk yard 3rd gen seat bottoms:
They would work fine with very little effort.
Hope that helps.
James
1969 Camaro - Dusty
Old 01-27-2008, 01:07 PM
NIIIIIIICE! It actually looks better than I thought it would!!! Any ideas on the seat backs? Keep us posted and please post the pics of progress.
Old 01-27-2008, 01:21 PM
thats not the typical lat d rear closeout, looks like he fabbed his own up.
Jake's Rod Shop
Old 01-27-2008, 07:32 PM
James OLC's Avatar
Putting a rear seat in with the Lateral Dynamics 3-Link is not that difficult. The bottoms fit with no problem and the upper would be be easy just needing to be trimmed to size.
We custom built the rear closeout starting with the transmission tunnel out of a skylark or something like that. It took a bit of work be we wanted the 3-link install to look factory from underneath and I think it was worth the effort.
No more rear seat updates. We played with this for a day but decided against a rear seat given the full cage.
Good luck,
James
1969 Camaro - Dusty
