Old 10-23-2007, 04:32 PM
staged67gspwr's Avatar
staged67gspwr staged67gspwr is offline
Default Wilwood 6 piston brake caliper/shock mount clearance issue question on GM A-Body
Guys,i ran into an issue i think,it seems the caliper body is too close to the shock mount on the rear of my 12 bolt,im not 100% its gonna hit but its very very close,has anyone ran into this problem?car is a 67 GM A-Body,any input appreciated.
George
`67 Buick GS ,"The Black Widow II"494ci,Stage 2,5-speed G-Machine
Old 10-23-2007, 04:42 PM
Looks real close but when it sets at ride height or when the suspension is compressed the shock body will move towards the inside of the car. Is it touching now?
Old 10-23-2007, 09:53 PM
hectore3 hectore3 is offline
You could go with a smaller shock body or grind a bit of metal off the caliper. But let me ask why such a large caliper on the rear of an A body? It must be way to much braking force back there.
Old 10-23-2007, 10:11 PM
4mm 4mm is offline
I would say the best way to solve the issue is to relocate the lower shock mount to gain more clearance.
Old 10-24-2007, 07:26 AM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
I would have had this problem if I would have went with the larger 4-piston calipers to match the 6-piston fronts. I chose to go with the smaller Dynalites in the rear and have no clearance issues......
Jason
www.fquick.com/ZZ3ElCamino
Old 10-24-2007, 01:23 PM
I guess i may have to relocate the shock mount which sucks,the only reason i got the 6 pistons for the rear was to match the fronts,i hate when they dont tell you things like this.
George
Old 10-24-2007, 01:50 PM
I feel your pain man. I purchased a Moser rear end with stock shock mounts, and I also ordered a set of Baer brake for it. Since I narrowed the rear end, nothing fit and I ended up selling the Baers at a loss and ended up going with the Wilwoods.
Jason
Old 10-24-2007, 05:13 PM
Well this is the email i got back from Wilwood
"Thank you for using Wilwood products.
The GM A-body is usually not a problem for caliper/shock interference. It is likely you will need to reposition the lower mounting point of the shock, as the caliper mounting position is not negotiable. I would look for a way to extend the lower shock mount inward toward the center of the rear axle to ease clearance. Feel free to call or write back with any further questions or if we can be of further service on this issue."
So it looks like i`ll have to weld a tab or something??
George
Old 10-30-2007, 06:21 PM
QSPres QSPres is offline
Banned
You could buy the adapter from KORE3 and run the calipers towards the front of the rear end.....
Old 10-30-2007, 08:11 PM
What or who`s KORE3?
George
