Old 11-02-2007, 12:59 PM
jmax jmax is offline
Default polyester filler
what is a good spray poly to use.
Old 11-02-2007, 01:12 PM
rubadub rubadub is offline
I have good success with z-chrome rust defender.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Old 11-02-2007, 01:23 PM
68protouring454's Avatar
i like standox's pe sprayfiller, its about the best out there, however look into whos ever paint line you will use and check there spray poly out, i would tend to stay away from evercoats or other knockoff's
Jake's Rod Shop
Old 11-02-2007, 01:55 PM
thanks jake, ive used evercoat before and was unhappy with the results. i use ppg's line and my local jobber suggested evercoat. Have u ever used the sata klc p for spraying it?I saw it at sema and was interested
Old 11-02-2007, 02:13 PM
i use a 3.0 tip for spraying the standox poly, and i use a iwata/air gunsa gravity feed poly gun, the klc is nice for urethane primer but too nice for poly, the air gunsa/iwata poly gun can be had for 100 bucks online and it works great, i only mix 1/2 quart at a time when spraying poly as it sets up too damn fast, and it is a mess to cleanup if it sets up in the gun, don't ask how i know.
at minimum i would use a 2.5 tip with the standox, standox's pe spray filler is around 50 bucks a quart with hardner, 6-8 will do an entire vehicle with 4 coats.
Jake's Rod Shop
Old 11-02-2007, 02:35 PM
thanks 4 the info jake
