Old 11-04-2007, 08:16 AM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Default 5.7 LS1 short block bare or with cam MTI stage II heads
selling bare short block
The shortblock was freshened up 35K ago (leak down performed when taken out..... no worse than 4% on any cylinder)
--stock crank, rods, pistons
--GM rings
--Clevite 77 Main and Rod bearings
--ARP rod bolts
--Pistons are flycut to .040 (baby flycuts)
will sell with or with out the M2 cam (228/234 .607/.598 110 +2)
$750.00 no cam
$950.00 with cam
Also will have the MTI stage II 2.05 valved heads that will be back from the machine shop for just a checkup and clean up. Will have new dual springs
1300.00 for the heads
Combo went 10.80's in 6-speed 3300 lb street car
don't want to ship the motor but will ship the cam or heads
Dallas TX area
Richard 214-793-0029
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 11-04-2007, 08:26 AM
deuce_454's Avatar
so how much for the heads and cam? would it work without flycutting...? what injectors did you run? and could you email a copy of the tune to give a startingpoint when the heads are installed?? ??
Jake: Hit it.
Old 11-04-2007, 08:40 AM
If you buy both I will go 1450.00 plus freight for the cam and heads. I do accept paypal to make it easy.
Will absolutly need flycutting with the big valves and this cam. I was running 30lb injectors which accually work as 36lb at LS1 fuel pressure. The tune was done for my by a local shop so I could not help there. I do not reccomend a mail order tune. I went that way at first and was way off ever thought I gave the tunner very detailed info. I would buy my own software and widenband then tune one myself if I did it again.
Only reason I am selling all my LS1 stuff is to build my Cutlass
Richard J.
Old 11-06-2007, 08:26 AM
MTI Heads just picked up from the machine shop. Fresh valve job, new dual springs ready to bolt on and go.
On Trevor Johnson's conservative bench here are the flow#'s
.200 104/137
.300 141/195
.400 171/245
.500 194/289
.600 211/301
.700 216/303
milled to 63cc
First $1300.00 takes them
Richard J.
Old 11-06-2007, 03:23 PM
heads are sold
Richard J.
Old 11-07-2007, 01:00 AM
deuce_454's Avatar
darn.... but the shipping here would have been stupid!
Jake: Hit it.
