Old 11-09-2007, 04:45 AM
oldzzy's Avatar
oldzzy oldzzy is offline
Default sandblasting pressure
Just wondering if there was a certain air pressure to use when sandblasting? I am blasting the underside of the floor, the firewall and the inner wheel tubs.
Shane
70 Olds W31 clone
http://www.flickr.com/photos/85638053@N00/
Old 11-09-2007, 06:05 AM
68protouring454's Avatar
go at it, you will not hurt any of those panels, i use 100 psi in my pressure pot blaster
Jake's Rod Shop
Old 11-09-2007, 07:00 AM
DHARROD's Avatar
DHARROD DHARROD is offline
100 should do it ..
Old 11-09-2007, 08:20 AM
B Schein's Avatar
B Schein B Schein is offline
Pressure is only part of it. You need large amounts of cfm. That is why people who do it professionally have those tow behide rotary screw compressors. They run around 90 psi and 100 or higher cfm.
Brian
Old 11-09-2007, 08:40 AM
true however my 7.5 hp two stage compressor pushed my 90lb pressure pot just fine, it can go thru 90lbs of sand without slowing down, then refill blaster and start again. but do not try it on anything smaller then a 5hp 80 gal 2 stage compressor
Jake's Rod Shop
