Old 11-30-2007, 02:01 PM
Birdman's Avatar
Birdman Birdman is offline
Default Shop lighting options
The light in my shop is attrocious. It seems like I am always finding spots in the garage that are dark, and always where I need light!
I have three 2-bulb flourescent shop lights hanging in the front part. They give ok light in the front, but the back of the garage is about as dark as it can get, especially with the garage door open.
I am going to add another flourescent under the shelf over the workbench to light up that area a little better, but I really need to get more light into the back of the garage.
Anyone have any suggestions? I had planned on adding another 3 2-bulb shop lights, but when the door is open it'll still be dark.
It is very frustrating, I pretty much have to have a drop light everywhere I am in the garage.
1998 Trans Am - BMR drop springs, BMR LCA relos, Bilstein shocks, Sportmax 18x9.5 wheels, lots of goodies, 6-spd swap, lQ9 swap
1968 Camaro (Patriot Dream project) - Iron LS1, T56, lowered and nitroused PT machine
PatriotDream.org - Help make a soldier's dream come true
Old 11-30-2007, 02:15 PM
68protouring454's Avatar
8 ft 4 bulb fluorescents
Jake's Rod Shop
Old 11-30-2007, 03:29 PM
bulldog19 bulldog19 is offline
Go with 8' 2-tube High Output strips. Each Tube is 110w, ballast is rated for cold temps so when you turn on during the winter and the garage is not heated they are still nice and bright. Expect to pay around $85 for the fixtures with the tubes. Plus also now they have an electronic ballast so the "hum" of the ballast is almost non existent.
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 11-30-2007, 09:03 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I've got 14 of these lights in a 36x34 area, my garage is sectioned off. plenty of light and have not changed a bulb in 6 years.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 12-01-2007, 06:41 AM
mark smith mark smith is offline
does the shop have a ceiling in it? mine did not have the dry walled ceiling in it for awhile due to running a/c lines and for storage purposes.after installing ceiling and painting it with a bright white paint the lights seemed to work alot better.my shop is 30 by 30 with 10 ft ceilings and i have 8 4 ft fast start flourecsents.still have a one area that could use a little more light but for now im pretty happy.
Old 12-01-2007, 08:39 AM
mazspeed's Avatar
mazspeed mazspeed is offline
These are the ones to go with. Not the most efficient, but good for cold weather garage lighting.
Old 12-03-2007, 01:49 PM
Birdman's Avatar
Thanks guys, I'll check into that. My shop is smaller, about 24x22, so a few of those should work great.
Old 12-04-2007, 01:20 PM
Silver69Camaro Silver69Camaro is offline
My 32x22 uses 14 4' double bulb T8 lamps. Lots of light. Almost like a surgical facility.
But the T8 bulbs are the way to go, hands down. No more T12 for me.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 12-04-2007, 01:32 PM
Birdman's Avatar
The main problem I have is the garage door blocking out most of my light. It takes up like half the garage ceiling when it is opened, and any lights above it are blocked out. I might run a couple of lights on the wall to the sides of it.
Old 12-06-2007, 02:41 PM
29od1 29od1 is offline
I have a 40'x60' shop with 12-8' T8 light strips. Each 8' strip has 4-4' T8 bulbs. Lighting is great and very efficient. The old T12 bulbs suck way too much power for what they output.
The strips will cost you about $40 from Lowes and 4-bulbs is about $9-$10. They're already set up for cold weather start.
