Old 12-05-2007, 01:22 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Does GM make a V6 Engine Based on the LS Technology?
To All:
Does GM make a V6 Based on the LSx Technology?
If so, what is it run in and do you have any specs on it?
Thanks,
Ty
Old 12-05-2007, 08:31 AM
jannes_z-28's Avatar
If you mean by technology a V8 without two cylinders, no
But they use the same kind of technology as Active Fuel Management, Variable Cam Timing and all other electronics found on the LSX series. They are also more compact with 60° angle.
The line of V6 engines is quite extensive.
Find more info here: http://en.wikipedia.org/wiki/GM_High_Value_engine
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 12-06-2007, 07:15 PM
tyoneal's Avatar
Jan
Jan:
Thank for the post. I found what I was searching for. it's the new V6 90 degree engine. Used in the, "Daytona Dash Racing".
As soon as I compile a bit more information I'll post it. It looks to be a unique V6 as compared their recent offerings.
Thanks,
Ty
