Awesome new Wilwood kits Available now
We now have the perfect tweaner kit between our 2 most popular brake packages, 12.2 Dynalite (4) piston packages, and the high end 13" (6) piston Superlite packages. The 13" (6) piston kit are twice the money of the smaller 12.2" (4) piston Dynalite kits. Besides the big price difference, the (4) piston 12.2" kits are very popular because they clear all 17" wheels with no problems, and the bigger kits may not depending on the wheel.
We are happy to announce we now have (6) piston Superlite 12.2" kits that price wise fall right in between the (4) piston Dynalite 12.2" kits and (6) piston Superlite 13" kits. these exciting new kits provide all the increased clamping power of the larger caliper and pad, the all important bling, with less expense and better wheel clearance for even 17" wheels!
So base Total Car Brake Packages using 12.2" rotors front and rear and (4) piston Dynalite Calipers are base price at $1750, Add (6) piston Superlight front calipers, add $400 and for $2150 you can have a awesome (6) piston / (4) piston 12.2" front and rear Total Car brake Package which includes:
Kits include:
Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Front Braided Brake Hoses
Rear Braided Brake Hose
E brake Cables for Internal E Brakes
Master Cylinder
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
Frank Serafine
