Old 12-12-2007, 02:46 PM
gearhead1186's Avatar
gearhead1186 gearhead1186 is offline
Default Which Rear Frame Rails??
My rear frame rails on my 69 camaro need to be replaced. Im planning on using DSE's deep tub kit and their quadra-link. Since Im replacing them should I step up to some more serious rails from 21st century or competition engineering? I know I need to cut up my trunk. This is fine as its being replaced anyways. Or should I get a set from yearone, weld em in and then box em up? Thanks in advance
Old 12-12-2007, 03:41 PM
freebird freebird is offline
i got a set of 21st century frame rails. My plan is to purchase a cross member for the from of the rails. I also will be running the art morrison tri 4 bar with DSE tubs. I will be placing the frame rail 42" apart.
Old 12-12-2007, 03:56 PM
how much hacking is required to put in aftermarket rails??
Old 12-12-2007, 04:09 PM
fesler's Avatar
fesler fesler is offline
We use Competition all the time and love the way they fit, you have to cut out the tubs and if you are going to change your frame rails I would build my own set of tubs as you can go wider and make them cleaner. here is what we just did in our 69 Camaro
If you look in the 1st picture you can see where the stock frame rail was and we move the new rail over as far as we can to clear the larger tire and still fit the fuel tank. The rest kind of give you an idea of what it takes to put these in with the tubs and how it will look.
We can fit a 345 in the back with lots of room to clear and thats a wide tire on a 19-inch wheel. Hope this helps in some way
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 12-12-2007, 04:27 PM
man that looks good.. but it also looks like alot of fab work and I dont know if I can do all that. I dont need to go more than 335. What did you have to do to make those rails fit. I know they dont go in the stock location and they are contoured to the body. I also want to use my rear seat.
Old 12-12-2007, 05:33 PM
j68bird j68bird is offline
I got my frame rails from this place. http://autoweldchassis.com/
The quality was excellent. They do require alot of work for the install, but I'm not a pro either. The back seat will need to be cut down, but I'm not sure how much yet.
J. Clear
68 Firebird Conv.
455/4spd under const.
Old 12-12-2007, 05:38 PM
did you get the regular rails or the profiled ones?
looking for strength with the least fab possible..
are you using DSE tubs and a quadra link?
Old 12-12-2007, 05:43 PM
Perry Mitchell Perry Mitchell is offline
I had 2''x3'' frame rails bent for me at Art Morrison's shop. I provided them with a template that I made from the bottom side of the floor pan after I removed the sheetmetal frame by drilling out the spot welds. I don't know if they kept a computer drawing of it when they were done or not. Might be worth a call. Don was the salesman that helped me, however, the last time I was there, I heard he retired. It fit perfectly. I simply welded it to the sheetmetal for a 100% connection. You can see pictures of the rails with the suspension installed to them before the assembly was welded in, on this link. www.lateral-g.net/members/mitchell
Old 12-12-2007, 05:56 PM
im assuming the AM bent rails would be equivalent to autowelds' profiled rails.. if this is correct how much did you pay for the morrison rails?
I want the exact factory shape(i want minimum fab) but with strong 2x3 11gauge steel.
Old 12-12-2007, 07:59 PM
It's been about three years now but I think it was around $150. I cut my floors because I ran the rails long and connected them to the front sub-frame while I was at it. You don't have to though, but I don't know why you wouldn't.
