if you are handy with a welder and a cut off wheel you can narrow the stock one... just be 201% sure that it is absolutely purger of gasoline vapours.... im not kidding!
you neet to cut two strips out of the tank one on each side of the fill tube, to retain it in the middle... cutting along (and on both sides of) a strip of 2 inch masking tape works great.. then you butt weld, preforably tig, the 2 ends and cener section together (great time to add baffles by the way!)
Jake: Hit it.
