Old 06-29-2005, 11:01 AM
69camaro638 69camaro638 is offline
Default 10 bolt housing code?
Can anyone here tell me what this 8.5" 10 bolt came out of? It is in a 68 Camaro that I just bought.
Front passenger side of the axle housing has this number - JB G094 2
Old 07-27-2005, 08:58 PM
hotwheels's Avatar
hotwheels hotwheels is offline
here is the only info i could come up with for those number's........
1971+ Rear Axle Code example: CB G 112 1 E
(CB = Ratio, G = Plant, 112 = 112th day of year, 1 = shift, E = Positraction Source)
cb=ratio G= Detriot Gear & Axle 94th day of the year 2=shift
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 08-14-2005, 10:03 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Post
Hollander's lists 3 possibles:
1. 73-74 Nova, 73-74 Ventura II (multi-leaf), 75 Apollo, 8.5", 3.08 (40-13), open
2. 72 Nova, 72 Ventura II (single leaf), 75 Apollo, 8.5", 2.73 (41-15), open
3. 80 Pontiac, 8.5", 3.23 (42-13), open
I think you probably have #1, if the leafs and all came with it (check the date on those).
Old 02-16-2006, 08:27 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default 8.5 in a 68 camaro
any of the GM X-bodys and cad sevilles had 8.5" the '75 and later versions had the 8.5 if v-8 equipped the 6 cyl then got a 7.5" rear - hope this helps
