Old 12-29-2007, 04:23 PM
ironworks's Avatar
Default Tube chassis 63 nova
We have started on a 63 Nova with a 5" ride height. We are going to put an Ls1 with a 6 speed in it with a Procharger. We will be using a Chris Alston front crossmember with a Chris Alston Billet triangulated four bar. We will be using Wilwood brake and I'm thinking 13 spoke Fikse wheels. We are looking at 245/17's, 335/18 with BFG. In this project we will be doing the Heavy fabrication and the New sheet metal work. I will also attempt to tell you how many hours are involved in each phase of the project to give an idea of the time it takes to build something like this.
In this project we are not going to fabricate everything, we want to make a high tech well fabricated car using smart parts. We have a handful of problems to over come in a small car with such a low ride height. The track width will be 51" so the tires can fully turn. The Chris Alston clip does not come with power steering so we are working to get a nice scrub radius with a 4.120 back space on a 7.5 wheel, we may run 8's but I'm not sure they will fit. We also need to keep the the flat hood, so engine height is important. Not to high, but not low. The location of the Procharger, How much of back seat we can have, these are some of the many issues to deal with.
We are budgeting 500 hrs to get a rolling chassis with rollcage. It looks like custom headers or block hugger shortie headers are a must already to improve gas pedal area. The cheap hooker swap headers are just not to friendly for space. The engine is set back into the firwall about 3". Wait until you see the rear frame rails
Current hours to this point are about 50, with 2 sticks of .120 DOM. And a Old nova floor in the scarp bin. The front suspension shows up on monday.
Old 12-29-2007, 04:39 PM
awr68's Avatar
awr68 awr68 is offline
Nice outline Rodger! It will be cool seeing the time breakdown.
Tony
'68 Camaro
Old 12-29-2007, 05:08 PM
deuce1963's Avatar
deuce1963 deuce1963 is offline
This looks awesome Rodger, I love following your work on John's car but I'm partial to 1st gens so this ought to be a treat. As far as 8" on the front I got this off of a Steve's post from Mike Weddle at Chassisworks when asked about the fronts on their clip:
a 17 x 8 w/ 4 3/4" bs with a 225-45-17 is an easy fit
18 x 8 could use a 40 series tire, maybe the 45.
a 235 -40 could be close, but have heard of that
going on.
Mike Weddle
Senior Sales Technician
Chris Alston's Chassisworks
Bob
Old 12-29-2007, 09:46 PM
ironworks's Avatar
Thanks, Mike is my sales guy and I have been talking to him about the exact numbers. 4.75" is the max or the car gets darty. The fikse wheels come in 1/4" increments which translates to 4.125, 4.375, and 4.625. I need to see exactly how wide I can run on the front. The track width has to be much narrower because of the ride height. I believe the bolt on clips have 56-57" Track width. I had to remove the stock Ac compressor and the Camaro alternator. Good thing no power steering or Ac on this ride.
Rodger
Old 12-29-2007, 10:22 PM
Vince@Meanstreets's Avatar
Looks like another great project. Can't wait to see more.
Old 12-30-2007, 06:40 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Looks like yet another nice piece to come out of your shop. Look forward to seeing this one come together.
Brent
Old 12-30-2007, 04:37 PM
ironworks's Avatar
Brent I think you just need to drive down here and check out everything. I will buy lunch from the Now Lateral-g famous Champs BBQ. I think more than 10 guys from here have been there. I wish I could get sponsored by them, my belly looks like I am.
Rodger
Old 12-31-2007, 06:12 AM
Ricochet's Avatar
Rodger-
I may just take you up on that offer!! Next time I roll down that way I will make it by. After seeing your stuff I'll proabbaly want to toss my junk in the corner...or spend more $$ I don't have!!
Keep up the great work!!
Brent
Old 01-02-2008, 07:20 PM
ironworks's Avatar
Some pics from Today. We will install the front crossmember and bend up the next section of the rear rails tommorrow.
Rodger
Old 01-02-2008, 09:10 PM
jason@gmachine jason@gmachine is offline
one word.
BADASS!
I like it. Jason
