Old 12-31-2007, 08:58 PM
latzoo latzoo is offline
Default 74 rear end for 67
I would like to know if rear end out fo a 74 Camaro fit my 67 Camaro. Wht would I need to look for and measure up to fit this rear end into my car.
Old 01-01-2008, 02:13 PM
AllSpeedAndy AllSpeedAndy is offline
For one, the '74 rear is wider (2 1/2 inches) and the spring perches are in
the wrong location. You can cut the perches then weld new ones in the right location. However your conventional back spacing for the '67 with the 60 inch diff will not work any longer, you'll need more back spacing to fit the tire you desire. Good luck
