Old 01-02-2008, 04:49 PM
speedfreak speedfreak is offline
Default Who is running a 5 speed Richmond ?
Wondering what clutch you guys are running.
I am running a dual friction Centerforce.
Having a problem with notchy feeling shifts not smooth at all.
Called Richmond today and they said It is most likely the clutch set up not disengaging all the way. They recommend .070 clearance with the cluch disengaged.
They said they have been having a few complaints about guys running the dual friction clutches not having enough clearance w/ the clutch disengaged.
Anyone else run into a similar problem?
Thanks,
Brian
Check out my web site.
www.screaminperformance.net
Old 01-02-2008, 08:38 PM
z066 z066 is offline
i am running a mccloud with a tremec and its great
