Old 01-03-2008, 02:05 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default 9" posi question
I have a 9" in my 69 Camaro. I am running standard rear gear oil and the POSI additive.
Problem is, the clutch in the posi unit is WAY too aggressive and it binds/catches very strong in slow speed turning. It makes the back of the car feel like it is going to tear off.
Question is - if the clutch is too aggressive, can I tone it down by changing fluid and NOT adding posi lube? Correct me if I'm wrong, but doesn't the posi lube help the posi clutch get friction - or is it the other way around?
Old 01-03-2008, 05:31 AM
AllSpeedAndy AllSpeedAndy is offline
What posi unit is in it?
Old 01-03-2008, 06:56 AM
69MyWay's Avatar
Good question. It is a clutch style, and I was told "carbon fiber" clutch disc. I didnt' pick it out. I had it build based on some trading and swaping to fit my 69 Camaro. However, I can't tell you the brand or anything beyond that.
This is really strange. This morning it is a record low temp in Florida (low 20s). When I backed out of the garage and then went out of the driveway, I didn't notice the horrific grab/snag/bump that is so typical and especially the more warmed up the car gets. By the time I was at work it was doing it again.
Old 01-03-2008, 11:06 PM
chicane's Avatar
chicane chicane is offline
What fluid are you running ?? And... which friction modifer are you using ??
I doubt you are going to be able to run the diff without using the friction modifier... unless the lube you use has it added to the base oil itself. Then again... you may just need to add a little more fric mod to subdue your issue.
Most differentials need 4oz of fric mod... but if the clutches were not soaked in fric mod to begin with (at the time of differential assembly) it will need time to mix with the base oil for it to do its job.
Old 01-04-2008, 02:06 AM
69MyWay's Avatar
I can't remember the weight of the oil - I looked up what would go into any stock Ford 9" application (oil weight wise). I added the fluid modifier that you can buy at the local auto parts stores. This has been an ongoing problem for a couple of years, but I have been driving the car everyday to keep miles off my new truck and it is driving me crazy!
Old 01-04-2008, 05:43 AM
When it is cold first thing in the morning, the oil is going to be thickest...
and by the time you get to work it has warmed up and problem came back.
This tells me your diff. likes the thicker fluid, now either what you have in it has broken down, or you need something of better quallity in there, like Royal Purple or another brand of performance fluids...As chicane said, I wouldn't
go with out the friction modifier, be sure to put that back in. But I would try a higher quality fluid than the general parts store stuff, before tearing in to it.
