Old 01-09-2008, 01:43 PM
olskooljr olskooljr is offline
Default Mini-tubs
I've decided to go the mini-tub route. I was looking at the Detroit Speed website and saw the minitub kit for 67 camaro was $1,320. I was wondering if there are more company that have kits for a cheaper price and will the kit be the only thing I need to worry about if I want to go with a wider wheel? Any info is much appreciated
Anthony
Old 01-09-2008, 02:14 PM
You will need to narrow your back seat and buy a new narrowed gas tank.
Old 01-09-2008, 02:46 PM
Jr's Avatar
Jr Jr is offline
DSE mintubs are $399
Old 01-09-2008, 03:17 PM
Oh I'm glad to hear that! I thought they cost alot more. Thanks for that info.
Old 01-09-2008, 03:27 PM
That is just for the tubs. The kit costs 1320.
Old 01-09-2008, 04:05 PM
zcrz zcrz is offline
narrowed tank
mini tub shocks = lots o money
labor to install
wider wheels
Old 01-09-2008, 04:16 PM
jwillia2's Avatar
jwillia2 jwillia2 is offline
whoa you forgot the biggest one narrowed rear end......
Ironworks Built 1969 Camaro AKA "HillbillyDLX"
Full DSE suspension LSA T56
Forgeline MonoBlock GA1R OPEN LUG
https://lateral-g.net/members/williams69/
Old 01-09-2008, 04:52 PM
68protouring454's Avatar
do not need narrower rear, stock width will work but you will only have a 2.5 inch lip.
minimum needed to do is mini tubs
if keeping leafs you need offset shackles and narrow tank 5 inches
or do 4 link of some type and narrow fuel tank
if you do the work yourself its worth doing the 4 link, as its not that much more money and alot easier to tune.
Jake's Rod Shop
Old 01-09-2008, 04:57 PM
Flash68's Avatar
Flash68 Flash68 is offline
Can you get by with a stock width tank with the Air Bar and QA1s and minitub?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-09-2008, 05:37 PM
jwillia2's Avatar
i guess your right, but in my case that was the whole point of it.. the fat tires with the big lip on the rim....I just faced the facts... there was no cheap way around it.. time i did it wheels tires, mini tub kit rear end, I spent over 7 geez..
