Old 01-15-2008, 12:03 PM
rwhite692's Avatar
Default C5 front suspension...Coilover choices?
I'm getting ready to fit the WD C5 subframe to the car (69 Camaro), and need to make a decision on the coilovers, for the front.
The car has a DSE Quadralink setup installed out back.
Any recommendations on coliover brands and types / options?
I'm looking at Koni, QA1, and Strange so far. Since the DSE Qlink has Koni's, I'm tempted to go that route and have Koni's all-round but, I don't want to ignore the offerings from the others, either...especially since the fronts will have the most influence on the handling characteristics...
I am thinking in the range of 475-500 Lb/in springs, since the engine is an iron block, and the weight of the turbos, etc... there is a lot of weight up front... -Rob
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 01-15-2008, 12:33 PM
dhutton dhutton is offline
Not sure if this is helpful or not but my Art Morrison subframe came with Strange coilovers and 550 lb springs. It was specified for an LSx engine. Unfortunately I have not completed the project so I cannot say anything about performance. Then again, even if it was finished I'm not sure I could give any worthwhile performance feedback...
Don
Old 01-15-2008, 03:10 PM
Bilstein - see Johnson's G-Force Cuda. http://g-forcecuda.com/ (tech sheet)
http://www.bilstein.com/hotrod.php
Chris Alston - See Rodger/John's Nova
http://www.varishock.com/vas_products.html#coilovers
Aldan Eagle
http://www.aldaneagle.com/#
Old 01-15-2008, 03:20 PM
Use what the C5R and C6R Le Mans cars use.
Penske 8300 series.
Tyler
Old 01-15-2008, 04:53 PM
rwhite692's Avatar
Penske 8300 series.
Tyler
Tyler - You have a PM (different topic)
My Lateral-G Page
My Shop Build:
Old 01-15-2008, 07:25 PM
rwhite692's Avatar
Don
Thanks, Don, that is good info...It may be that I need even stiffer springs, since my setup surely weighs in at quite a bit more than a typical LSx setup...
My Lateral-G Page
My Shop Build:
Old 01-15-2008, 10:05 PM
Vince@Meanstreets's Avatar
Hey Rob,
if you are running Koni's in back i'd recommend the same for the front. Make sure you do a ride height mock up to be sure you pick the right range coil over and spring length.
550's are a great starting point.
Old 01-16-2008, 05:03 PM
rwhite692's Avatar
Thanks Vince, yes that is my intention; I will mock up first before ordering...I am leaning towards Koni's, for the front.
My Lateral-G Page
My Shop Build:
Old 01-23-2008, 02:49 PM
Silver69Camaro Silver69Camaro is offline
Start with 550's
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 01-23-2008, 04:10 PM
LateNight72 LateNight72 is offline
http://performanceshock.com/
