Old 01-17-2008, 08:52 PM
jeff s's Avatar
jeff s jeff s is offline
Supporting Vendor
Default Schwartz 2nd gen Camaro full frame
It's now available. No cutting of the floor is required and the stock gas tank will work. A 345 rear tire will fit with a mini-tub and 275 are no problem in the front. Coilovers at 4 corners or Air Ride shockwaves.
Initial data shows we took about 145# off the front and re-distributed 60# to the rear. The total weight loss is greater than 85# as we ditch the heavy rear leaf springs. Of course we wont know exact distribution percentages until our 81 Turbo Trans Am project is further along.
Weight of the assembled stock GM front subframe is 427# with brakes, ps box, sway bar. The Schwartz Second gen Camaro Firebird full frame, with 14" front brakes, all front suspension, power steering rack, both front and rear sway bars, crossmember, shocks, springs is 342#.
We've ramped up production capabilities and at the present time can ship any chassis including our A- Body chassis in 2 weeks from order date.
Thanks,
Thanks,
Jeff Schwartz
SchwartzPerformance
Where classic style meets modern technology.
Website : Facebook : Twitter
