Old 01-22-2008, 08:55 PM
av8or32 av8or32 is offline
Default Firebird Brakes
my 69 firebird has been converted to manual front disc brakes with stock drums. I would like to add a power booster, put larger discs on the front and add a rear disc kit. I don't need a racing setup, just a good sport kit that won't push the wheels out and will stop about 450 hp.
Old 01-22-2008, 09:39 PM
We have a Total Car Brake Package using Wilwood kits that does the entire car.
Here is the sales pitch
Prodigy Customs introduces our Total Car G-Machine Brake Packages for Camaro, Chevelle, Nova, F body, A body, G Body, Ford, Mustang, Mopar and many others featuring the worlds best brakes, Wilwood Disc Brakes! Prodigy Customs EXCLUSIVE Total Car G Machine Brake Packages takes all the guess work out of your 4 wheel disc brake conversion. Our kits include front and rear Wilwood brakes in the size of your choice, front sizes from 10.75" - 14" rotors for all popular applications, Rear brakes include INTERNAL E BRAKE in sizes from 12.2" to 14" for all popular applications. Calipers are available in Four Piston to Six Piston, Dynalite and Superlite Calipers Our exclusive Total Car G-Machine brake packages include everything required to convert you original brakes to monster 4 wheel disc. Call for your exact application.
Kits include:
Wilwood Parts Include:
Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Prodigy Customs Parts Include:
Front Braided Brake Hoses
Rear Braided Brake Hose
E brake Cables for Internal E Brakes
Master Cylinder
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
12.2" (4) Piston F / 12.2 (4) Piston R W / Internal E brake $1750
NOTE:
($1750 Kit includes BLACK CALIPERS and NON Drilled / NON Slotted Rotors)
Options include:
Red, Blue, Yellow, Silver and Polished Calipers are A + $200 Option,
Drilled and Slotted Rotors are a + $200 Option
Wilwood Aluminum Dual Reservoir Master Cylinder is a + $170 Option
Dual Diaphram Polished Stainless Power brake Booster $200
KIT AS SHOWN WITH RED CALIPERS, DRILLED AND SLOTTED ROTORS, AND POWER BOOSTER IS $2350.
Frank Serafine
