Old 07-08-2005, 05:43 AM
PH68CAMARO PH68CAMARO is offline
Default Center Force Dual Friction Clutch
Spent all night trying to get my 4 speed muncie back in with no luck , the tranny end of the shaft would not find its way into the new needle pilot bearing any ideas, we used the clutch tool to align everything prior. every time it looked like it would just mis align on the edge of the bearing. i have never run into this being that hard any thoughts before we get into again tonight would be great .
Old 07-08-2005, 06:51 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
Can you get someone to press the clutch pedal in while you push the tranny forward. The disc will then be able to self-center a bit. I found it a pain due to the splines needing to be aligned ( fine spline input shaft).
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
