Old 02-03-2008, 09:49 AM
chrismoe's Avatar
chrismoe chrismoe is offline
Default Checking interest \ value
Hello all,
Hope everyone is well. The purpose of this post is to check interested and perhaps assess the value of my 68 pro-tour Camaro. As some of you may know, I bought this car from a forum member a few months back. It was almost done and almost perfect when I got it. It is now "done". Tracy, the builder, did a terrific job building the car. The only "problem" was some welds on the 4-bar rear end did not fully penetrate so I had all of the welds ground off and re-welded. Since owning the Camaro I have done small things like slap on a Marquez Design billet gas cap, replace the front seats, have the trunk upholstered in a body color matching scheme, have the alternator replaced and had the car Dyno tuned. You may remember a post form me a few months back where I was jumping out of my chair after seeing the car made 638 ft. lbs. of torque and 593 HP AT THE REAR WHEELS!
At any rate, the car is beautiful, monstrously fast, reliable and just a killer car. All that said, I am already bored and thinking about moving on to another car (for those of you who know me, you know I have this sickness). So, I was hoping to measure interest in this car both from a dollar as well as a trade perspective. At the risk of posting the longest thread in the history of Lateral-G.net, here is some details on the Camaro as well as a link to an Internet picture hosting site with loads of pictures of the car. I also have some small Quicktime videos so you can hear the car. If you would, could you scan the attached document and take a look at the pictures and let me know what you think? Any input would be very welcome.
Camaro Details:
BODY \ PAINT: COMPLETLY RUST FREE BODY. THE CAMARO HAS ALL OF ITS ORIGINAL PANELS/DOORS AND WAS A GREAT DONOR CAR TO START WITH. THE PREVIOUS OWNER HAD THE CAR PAINTED A COUPLE YEARS AGO BUT THE CAMARO NEVER SAW THE LIGHT OF DAY AS IT WAS A PROJECT WITH NO END IN SIGHT. IT HAS A BEAUTIFUL, TWO STAGE PAINT JOB (BURIED IN HIGH-QUALITY CLEAR) AND IS SEBRING SILVER WITH BLACK STRIPES. THE FIREWALL WAS FLUSHED WITH A DETROIT SPEED AND ENGINEERING PLATE. THE FLOOR WAS COVERED WITH SOUND DEADENING MATERIAL TO KEEP THE SOUND AND HEAT TO A MINIMUM. ADDED MARQUEZ DESIGN BILLET GAS CAP. THE BODY IS VERY STRAIGHT AND ALL GAPS LINE UP GREAT.
MINITUB: PROFESSIONALLY DONE AND IT LOOKS GREAT!! THE DETROIT SPEED AND ENGINEERING WHEEL TUBS LOOK LIKE THEY CAME FROM GM EXCEPT FOR THE FACT THAT THEY HOUSE HUGE 335/30 MICHELIN PILOTS.
REAR SUSPENSION: THE REAR WAS UPDATED WITH THE LATEST TRICK SUSPENSION, ALSON CHASSISWORKS G-BAR. THE G-BAR IS A CANTED FOUR BAR REAR SUSPENSION THAT IS LIGHT YEARS AHEAD OF STOCK LEAF SPRINGS. THIS TRICK SUSPENSION USES VARISHOCK QS1 ALUMINUM COILOVERS THAT ARE ADJUSTABLE AND ALSO ALLOW EASY CHANGES IN RIDE HEIGHT.
FRONT STEERING/SUSPENSION: THE FRONT /STEERING/SUSPENSION WAS UPDATED WITH A TON OF TRICK PARTS: FULLY ADJUSTABLE TUBULAR UPPER CONTROL ARMS, SCREW IN HOWE NASCAR TALL BALL JOINTS, GLOBAL WEST COIL SPRINGS, BILSTEIN FRONT SHOCKS, HUGE HOCHKIS SWAY BAR, KRC ALUMINUM POWER STEERING PUMP, KRC REMOTE ALUMINUM RESERVIOR, HIGH PRESSURE STAINLESS BRAIDED LINES AND A QUICK RATIO POWER STEERING BOX. THE BODY IS MOUNTED TO THE CHASSIS WITH SOLID BODY MOUNTS AND THE FRAME IS TIED TOGETHER WITH GLOBAL WEST SUB FRAME CONNECTORS. THE HANDLING ON THIS CAMARO IS ABSOLUTELY RIDICULOUS!
ENGINE: THIS IS A CUSTOM PRO BUILT 580 ci MOTOR. BUILT BY rebirdraceengines.com. THIS IS NOT A GM CRATE MOTOR! THIS CUSTOM BUILT BULLET HAS A DIFFERENT BORE/STROKE COMBO THAN A GM CRATE MOTOR, 4.5" STROKE x 4.53" BORE. THE LONGER STROKE PROVIDES MORE TORQUE AND MORE HORSEPOWER AT A USABLE STREET RPM. THIS STREET MOTOR IS FULL OF KILLER PARTS AND OF COURSE RUNS ON PUMP GAS WITH NO ISSUES BECAUSE OF ITS MILD COMPRESSION OF 10:1. THE BOTTOM END IS ALL 4340 STEEL AND THE BLOCK IS A MERLIN II. THE HEADS ARE FULLY PORTED DART ALUMINUM HEADS TOPPED OFF WITH A FULLY PORTED DART INTAKE AND A TRICKED OUT AED 950 HP HOLLEY CARB. THE VALVE TRAIN IS HANDLED BY A COMP CAMS ROLLER SHAFT, COMP CAMS ROLLER LIFTERS, COMP CAMS STAINLESS FULL ROLLER ROCKERS, COMP CAMS PUSHRODS AND AN ALUMINIUM STUD GIRDLE. THE IGNITION IS A FULL MSD SYSTEM WITH A PRO BILLET DISTRIBUTOR, MSD BLASTER III COIL, MSD 6M BOX AND MSD PLUG WIRES. THE CAR WAS DYNO TUNED BY A WLL KNOWN SPEED SHOP IN SAN JOSE, CA. I HAVE DYNO SHEET THAT SHOW THIS CAR MAKE 638 FT. LBS. OR TOURQUE AND 593 HP AT THE REAR WHEELS. AND, IT IDLES AT 900 RPM, RUNS COOL AND IS A *****CAT UNTIL YOU ROMP ON IT. THE DYNO IS FROM NEW ZEALAND AND TO THE DYNO MNAUFACTUERE ANY DRIVE WHEEL IS A FLOYWHEEL SO PLEASE DO NOT BE CONFUSED BY THAT PORTION OF THE DYNO PICTURE. IF YOU LOOK AT THE PICTURE IT ACTUALLY SAYS CHASSIS DYNO. AS I HAD HOPED, THE CAMARO IS REALLY QUICK AND CAN KILL THE REAR TIRES AT WILL.
EXHAUST: THE HEADERS ARE HIGH DOLLAR COATED DYNATECH PIPES CONNECTED TO A 3" SPINTECH EXHAUST SYSTEM. THE MUFFLERS ARE LARGE SPINTECH XL TO KEEP THE NEIGHBORS AND COPS A LITTLE HAPPIER. THERE ARE CURRENTLY NO TAILPIPES PAST THE REAREND SO IT DOES HAVE A WICKED SOUND.
TRANSMISSION/CLUTCH: THE TRANNY IS A TKO 600 5 SPEED WITH A .64 OVERDRIVE. THE FIVE SPEED OFFERS SUPER QUICK RATIOS FOR DRIVING IN TOWN AND A BIG OVERDRIVE FOR HIGHWAY CRUISING. THE TRANNY MATES TO THE BIG MOTOR WITH A SFI STEEL FLYWHEEL, THE CLUTCH DUTIES ARE HANDLED BY A KILLER MCLEOD UNIT (SMOOTTH WITH NO CHATTER) AND THE BELLHOUSING IS A MCLEOD SFI BLOWPROOF HOUSING. THE CLUTCH IS ACTUATED BY A TILTON HYDRAULIC CLUTCH MASTER AND A MCLEOD HYDRAULIC THROWOUT BEARING. THE SMOOTH HYDRAULIC CLUTCH ALLOWS YOU TO RUN A MUCH STRONGER CLUTCH ON THE STREET WITHOUT BURNING DOWN YOUR LEG AT EVERY STOP LIGHT.
REAREND: THE REAR IS A FULL BLOWN MOSER ENGINEERING 12 BOLT WITH 33 SPLINE AXLES, 3.73 GEAR, 1350 YOKE, 1/2" STUDS AND BIG FORD HOUSING ENDS. THE REAR IS BULLETPROOF AND READY FOR YOU RIGHT FOOT!
BRAKES: THE BRAKES CONSISTS OF A COMPLETE WILWOOD DISK BRAKE SYSTEM WITH A PARKING BRAKE. ALL ROTORS ARE DRILLED, SLOTTED AND COATED FOR KILLER LOOKS. THE MASTER CYLINDER IS AN ALUMINUM WILWOOD PIECE THAT DEPRESSES EASILY AND PROVIDES A GREAT FEEL FOR THE ROAD. THE CAR STOPS ON A DIME AND THE BRAKES ARE VERY QUIET (NO SQUEACKS). ALL LINES THAT CARRY FLUID ARE STEEL BRAIDED. THE PARKING BRAKE CABLES ARE MADE BY LOKAR AND PROVIDE A VERY SMOOTH ENGAGEMENT AND DO NOT HANG BELOW THE EXHAUST LIKE THE FACTORY SYSTEM.
WHEELS/TIRES: THE WHEELS ARE A BEAUTIFUL THREE PIECE DESIGN BY FORGELINE AND ARE THE ULTIMATE FOR A STREET CAR. THE WHEELS HAVE POLISHED, DEEP LIPS AND FORGED ALUMINUM CENTERS COLORED IN GUN METAL. THE GUN METAL COLOR REALLY BOUNCES WELL OFF OF THE SEBRING SILVER PAINT. THE WHEELS ARE 18x8.5 FRONT AND 18x12 REAR WITH 335/30 MICHELIN PILOT SPORT TIRES.
COOLING/PULLEYS: THE COOLING CHORES ARE HANDLED BY A HUGE C&R NASCAR BRAND RADIATOR. THE SYSTEM IS COMPLETE WITH AN OVERFLOW/RECOVERY SYSTEM, TWIN ELECTRIC FANS AND AN ALUMINUM WATER PUMP. THE SERPINTENE PULLEYS ARE POLISHED ALUMINUM FROM KRC AND LOOK GREAT. THE CAMARO RUNS COOL IN TOWN OR ON THE HWY. IT NORMALLY CRUISES AT 180 DEGREES. AND ON A HOT 90+ WILL CREEP UP TO 190 IN BUMPER TO BUMPER TRAFFOIC THEN GO RIGHT BACK DOWN TO 180 OR LESS ONCE YOU START MOVING.
INTERIOR: THE INTERIOR IS ALL NEW AND COMPLETE WITH A CENTER CONSOLE, CARPET, NEW SKINS, DASH, PACKAGE TRAY, HEADLINER, DOOR PANELS, MOMO LEATHER STEERING WHEEL, VINTAGE AIR A/C AND HEATER, AND FULL OF AUTOMETER ULTRA LITE QAUGES. SEATS ARE VERY COOL PRO-CAR \ SCAT PRO-RALLEY SEATS THAT ARE VERTICALLY STICHED TO MATCH THE REAR SEAT, HAVE GREAT LUMBAR AND MATCH THSI CAR PERFECT. I ALSO HAD THE TRUNK UNPOSLTERED IN A COLOR MATCHING SCHEME. THE SPEEDO IS A PROGRAMABLE 5" ELECTRIC GAUGE WITH DIGITAL ODOMETER. THE FOUR GAUGES IN THE CENTER CONSOLE INCLUDE A CLOCK, FUEL, OIL PRESSURE AND WATER TEMP. THE SHIFTER BOOT IS A NASCAR SFI NOMEX BOOT AND OFFERS A COOL ALTERNATIVE TO THE BORING RUBBER STYLE.
There is much more to tell but that should give you some basics. I took the car it to Goodies Speed Shop (www.goodies-speedsop.com) here in San Jose for a once over and for Dyno tuning. They can serve as a great reference for this car.
Here is a link to that online picture hosting site. To really see pictures of this car you need to click on any one picture to start a slide show of 5X8 sized pictures and then once inside the slide show you can click on any 5X8 picture to see it full size. Some of the pictures of the trunk are before I had it upholstered and some of the pictures of the engine are before the Vintage Air Heat and Cooling was added. You may have to cut this link out of this document and paste it into your browser but it will get you to the picture hosting site. Here is the link:
http://www.fototime.com/inv/A6B3CADC6D37356
Thanks in advance
Chris
Old 02-03-2008, 11:02 AM
mazspeed's Avatar
mazspeed mazspeed is offline
Hey Chris, Let me see the car. You have time this week?
Old 02-03-2008, 11:19 AM
awr68's Avatar
awr68 awr68 is offline
Looks like it turned out great Chris!!
What do you want to build next?
Tony
'68 Camaro
Old 02-03-2008, 12:02 PM
Flash68's Avatar
Flash68 Flash68 is offline
Awesome car!
Where are those quicktime videos?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-03-2008, 12:31 PM
Lateral-g Moderator
How much ground clearance do you have with the oil pan and headers? Cool car.
Old 02-03-2008, 12:36 PM
awr68's Avatar
Not picking it appart at all but this caught my attention, Is the bottom of the rear coil overs really as low as they look in the pics...if so thats pretty unsafe! Not to mention illegal if they are below the bottom of the wheel...
Tony
'68 Camaro
Old 02-03-2008, 01:47 PM
chrismoe's Avatar
Default Ground clearance, etc. and some short videos
Anthony,
Thanks for the kind words on my car. I wish I could take all the credit for how nice the car tuned out. Almost all the credit goes to Tracy. As for ground clearance and the rear coil overs. Yes, they look low but they do not sit below the wheel at their lowest point. Clearance is not an issue at all. As for what I hope to get into next, I am pretty open but perhaps a Mustang or even another Camaro.
Mike,
I am around after work most of the week. And, the weather is finally supposed to be clearing up. What day are you thinking?
Stuart,
No clearance problems with the oil pan but the headers are low. I do not scrape at all during normal or even spirited driving but I drive up steep driveways sideways. Same with speed bumps. Also, not rub from the tires (of course).
Flash68,
Thanks for the kind words. And, hopefully these small Quicklime videos will work. They come from my girlfriends phone so the quality sucks but at least you can hear how quickly this car grabs revs. Pretty cool considering it makes so much HP this Camaro makes. If the videos do not work PM me with your email address and I will email them to you. Last word on this...turn up your speakers because the audio is quiet, and, because it sounds good loud.
https://www.youtube.com/watch?v=ey0bZDGXooU
https://www.youtube.com/watch?v=Wfu_tLq3aag
Take care,
Chris
Old 02-03-2008, 02:02 PM
Flash68's Avatar
Chris, thanks for posting those videos. Awesome sound and amazing throttle response it sounds like.
I assume that is the direct kit from Spintech is what is on there? With the Sportsman XL muffs? I am thinking of getting the same kit for mine. That sounds great.
Good luck if you decide to sell it. Not sure what it would bring on the open market, but I would be willing to bet ebay or even BJ would bring you your top dollar. Never hurts to throw it on ebay with a pretty high reserve just to test the market. You have such a great parts list there it could bring big $.
Thanks again.
2014 4 tap Keezer
Old 02-03-2008, 04:29 PM
chrismoe's Avatar
Default Exhaust
Flash68,
Yea, they are Spin Tech's Sportmans XL's. They sound wicked in person.
Take care,
Chris
Old 02-03-2008, 05:16 PM
mazspeed's Avatar
Originally Posted by chrismoe
Mike,
Take care,
Chris
Tomorrow anytime. You interested in another cool camaro, or a cool built up 57 Bel Air?
What's on your mind as far as trades go?
