Old 02-05-2008, 08:58 PM
jeff s's Avatar
jeff s jeff s is offline
Supporting Vendor
Default 700 hp na pump gas LS7
Been on the dyno since last Wed.
We got to 690 hp today on BP pump premium fuel, idles smooth at 920 rpm.
Stock plastic intake, stock DBW throttle body, Tuned GM Corvette ecu, Custom Cam, head work, Schwartz MAF.
Maybe we'll hit it tomorrow, 2 more LS7's with different parts to test next.
Videos soon.
Thanks,
Jeff Schwartz
SchwartzPerformance
Where classic style meets modern technology.
Website : Facebook : Twitter
Old 02-05-2008, 09:45 PM
4mm 4mm is offline
Very nice numbers, who would have imagined that from a NA LS7 one year ago.
Is the intake and tb ported? A dyno graph would be nice to check out the torque.
Old 02-05-2008, 11:36 PM
Thank you Jeff for real intresting numbers. Can you share the torque numbers as well ? I would like to know how are they compared to stock at lower rpms
63 Z06
Old 02-06-2008, 04:00 AM
deuce_454's Avatar
wow, what does this beast cost?? and what exhaust did you run on the dyno?? how much will a free flowing dual subtract from that number?? and what octane rating is minimum fopr that engine
we have 95 on pump here.. would that enable you guys to free up some additional power??
Jake: Hit it.
Old 02-06-2008, 12:35 PM
jeff s's Avatar
Supporting Vendor
Still on the dyno today with a couple other combos.
That was with 93 octane BP, around here everything has 10% ethanol in it.
Stock plastic intake on this one. Our headwork, our custom MAF, our tune in the GM ECU, our specs on the cam.
It's easy to make big numbers with these engines, by throwing more cam at it, but the key is a streetable package, which we have.
It has 450 ft lbs at 3000, 500 lbs at 3800, 574.3 at 5500, 517lbs at 7000
676 hp still at 7400. Idles smooth at 920.
Peak hp was 7000 rpm
peak tq at 5500, but the curve is flat as a pancake.
Thanks,
Jeff Schwartz
SchwartzPerformance
Old 02-06-2008, 03:45 PM
YancyJohns's Avatar
YancyJohns YancyJohns is offline
That's awesome Jeff.
Now, what can you do with an LS3? I'll send you mine.
Old 02-06-2008, 03:47 PM
radrambler's Avatar
Default wow
jeff
thats some nice #s . whats that setup going into or are you just testing your combo on the motor ?
radrambler
Old 02-06-2008, 04:14 PM
Nate_ERC's Avatar
Nate_ERC Nate_ERC is offline
Is the shortblock OEM?
www.eckertsrodandcustom.com
Old 02-06-2008, 05:25 PM
frankenstang frankenstang is offline
Stock bottom end guys! Aftermarket rod bolts.
He has some customers overseas that are interested in BIG #'s
check out pics of the car at www.fquick.com/frankenstang
Old 02-06-2008, 05:39 PM
jeff s's Avatar
Supporting Vendor
All our packages we upgrade the rod bolts, this one had Forged Mahle pistons, and re balanced. This was with our Schwartz Ultima headers, which are fairly short tubes, 3" exhaust on the dyno. These had head mods as well.
Late today we made 730.7 hp with a similar combo, different head work, a modified alum GMPP intake, the Schwartz Power Spacer and the drive by wire TB. We were able to maintian the flat curve despite shorter runners.
3 of these engines tested are going into Ultima GTR's in Europe, one is going into a FFR GTM and another we are installing in a 64 Malibu SS.
Still testing tomorrow, so probably wont post vids til monday.
Thanks,
Jeff Schwartz
SchwartzPerformance
