Originally Posted by phonedude_mln
as FETorino says below, go to http://www.fordfe.com/ -- this has been
covered before several times. and since companies like Scat are making
reasonably priced stroker kits (4.25"), no reason to not go big...
Yes, of course the rotation can be changed to std.... Just wanted to point out the reverse rotation issue, in case someone was not aware, and thinking of using it as-is. And hopefully the engine has only seen a closed cooling system (FWC) if not, good luck!
