Old 02-10-2008, 07:03 AM
01somta 01somta is offline
Default Seam Sealer interior or exterior?
Should you use the seam sealer on the inside or outside joint? Or, seal as much on the interior as possible and then do the rest exteriorly or seal as much on the exterior and then do what you can't reach on the exterior seal on the interior? This is all undercarriage and trunk pan seams.
Thanks Dustin
Old 02-11-2008, 05:13 PM
What is the difference in a 2 part (lord fusor or similar) and a 1 part (fast n' firm or similar) seamler
Old 02-12-2008, 05:38 AM
GMracer's Avatar
GMracer GMracer is offline
not sure on the difference, but I personally would seam seal both sides before paint. that's just how I do it.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 02-12-2008, 08:18 AM
Musclerodz's Avatar
Fast-n-firm is old technology. You almost have to use parts sealers and special guns to get the good stuff anymore. I seal anywhere I don;t want water or debris to get to.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-12-2008, 03:23 PM
I am using a two part (fusor) on interior and ext.
