Old 02-15-2008, 04:26 AM
murtah's Avatar
murtah murtah is offline
Default LS1 vs LS2 oil pans and other ?????
Which is better? They both hold 5.5 quarts although I have heard that the screen on an LS2 pan is a little longer. I haven't been able to confirm it on LS1 tech though.
The LS1 pan is a little easier to find used.
My LSX build up will be stroked to 7 liters. Do any of you LSX builders think 5.5 quarts might not be enough for 7 liters? (eventhough the LS2 pan is used on the 6.2 liter LS3)
Thanks in advance,
Jim
Old 02-18-2008, 12:17 PM
pist0lpete pist0lpete is offline
As far as oil control goes the LS1 pan is better because of its bolt on baffling with a superior design whereas the LS2 pan has the baffling cast in the pan as a measure to save money.
