Old 02-16-2008, 06:55 PM
bucks69 bucks69 is offline
Default Wilwood floor mount Master Cylinder
Has anyone used these and if so what did you think of them? Do you happen to have any install pics? I am cutting out my floor and losing some depth and was thinking about using these so I could sink them into the floor. This is on a 69 Camaro. I will have to install 2, 1 for clutch and 1 for brakes. If you have any better ideas please let me know Thank You
Old 02-18-2008, 08:33 AM
ironworks's Avatar
If you get on my website you can see some one of the install on Johns Nova. The master cylinders are the same no matter if you use the floor mount or firewall. The pedal assembly is just different.
www.ironworksspeedandkustom.com look under the ZO6 nova.
Rodger
Old 02-18-2008, 10:38 AM
Thanks Rodger I had already checked your install out. Appreciate the info.
