Old 02-19-2008, 09:55 AM
unwrittenlaw191 unwrittenlaw191 is offline
Default DSE Mini Tub?
How are the location of the front of the leaf spring moved in? I know that the rear are moved with the off-set shackels. Just trying to decide if I should buy this kit.
Old 02-19-2008, 10:08 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
The physical location of the front spring hanger is in the factory location. If anything the spring would not be centered on the bushing. This applies to first gen not sure of the others.
Old 02-19-2008, 10:13 AM
yellowrallys yellowrallys is offline
The front of the spring does not relocate. There is enough movement in the hangers to enable the spring to line up with the offset rears.
Old 02-19-2008, 11:44 AM
Musclecar's Avatar
Musclecar Musclecar is offline
Buy it, you'll like it!
Carless at the moment
Old 02-19-2008, 11:57 AM
dj3 dj3 is offline
Anyone got any pics? Im interested in this as well.
Old 02-19-2008, 12:22 PM
Jimmy Sean's Avatar
Pic's of what? There are alot here http://www.detroitspeed.com/projectp...oject_page.htm
Old 02-19-2008, 12:24 PM
dj3 dj3 is offline
I wanted to see how the relocated springs looked and how bad of an angle it is. Thanks for the link.
Old 02-19-2008, 02:01 PM
907rs's Avatar
907rs 907rs is offline
The DSE Hangers actually straighten the angle of the spring (not that it matters). From the factory, the frame rails and springs angle to the outside of the car toward the rear.
Bill
Old 02-19-2008, 02:42 PM
NEVER ENOUGH NEVER ENOUGH is offline
I saw this on another site, thought it was helpful..
Stock leaf springs look (similar although a bit drastic) to this / \
DSE offset shackles make the leaf springs look like this ! !
This member has no signature.
Old 02-19-2008, 04:08 PM
dj3 dj3 is offline
Thanks for the info. I had always thought there was major fab work required for the DSE kit. Looks like you could get a body shop to install the tub and do the rest in the driveway.
