Old 02-19-2008, 10:28 PM
CRJpilot CRJpilot is offline
Default GM 10 bolt EATON or AUBURN posi unit??
Building a 8.5 10 bolt rear for my 67 camaro. And was wondering what posi unit is stronger or better, the Eaton or Auburn. Going with 3.73 for gears. Any help would be great. Would love to have a 12 bolt but can't find the cash for that..
Gotta pay to play!
Old 02-19-2008, 11:12 PM
chicane's Avatar
chicane chicane is offline
Uhmmmm.... an Eaton.
Auburns are 'throw away' units. However, with their "D-Rex" exchange program it make replacement eaiser to swallow when a unit does fail... all for about $100, not including time, other parts and labor.
Not to forget to mention that the Eaton is tunable... and rebuildable, no less.
Old 02-20-2008, 07:09 AM
Wayne S's Avatar
Wayne S Wayne S is offline
May I suggest a Richmond Powertrax posi unit. That's what I run in my 8.5" in my Camaro. It's bullet-proof. It's made of something called zitanium, which they say is 67% stronger than titanium. I'm very happy with it. It's like a spool when you're going straight and seamlessly unlocks on the turns. It's very smooth on the street, and it was pretty easy to install, too. Only thing is that you need an open carrier to install it into, but open carriers are a dime a dozen. Plus, it's only around $450 through Summit or Jeg's.
Wayne Smith (70Camaro406 on the other boards)
'70 Camaro - 406 - Street/Strip being converted to Pro-Touring (best 1/4 run - 11.05 @ 121, 1.50 60' - All Motor)
View pics at:
http://www.flickr.com/photos/83785049@N00/
A couple vids of it revving:
https://www.youtube.com/watch?v=iuyIgo06Liw
https://www.youtube.com/watch?v=4Ilcp3a9fik&feature=user
https://www.youtube.com/watch?v=K95WCTdsbpY&feature=user
Old 02-21-2008, 08:12 PM
PhilM PhilM is offline
Having had both, I can highly recommend the Eaton. Threw piles of nitrous at it with an old richmond 6 speed.
Old 02-21-2008, 09:22 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Let's see some pictures of this 67!
Curtis
Old 02-25-2008, 05:01 PM
I found something else caled DETROIT TRUETRAC posi, uses all gears and no clutches and is a limited slip unit. Anyone heard or used this one?
some pics of the car are here:
https://lateral-g.net/members/rogers/
Gotta pay to play!
Old 02-27-2008, 08:49 PM
chicane's Avatar
Sure... just dont use it for drag racing... as impact loading will destroy it in no time at all.
Old 02-27-2008, 09:39 PM
RomsMotors's Avatar
RomsMotors RomsMotors is offline
I have setup a lot of Auburn and Eaton units in my shop. I have not had any problem with anyone coming back and complaining of problem with either one. I personal run Eaton in all of my cars I build. I do like with Eaton’s you can rebuild them and change the spring rate for the side gears from a 400lbs to 800lbs spring.
Old 04-10-2008, 02:15 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Default Where can one get rebuild parts for an Eaton?
I've got an Eaton posi in the 8.5" 10 bolt I'm building for my S10 and I'd like to rebuild it before I put it into the truck. Does anyone offer side gears to allow bigger axles, too? 10 bolts seem to be forgotten on most vendors websites.
Thanks.
Ric
Ric
2002 S-10, Daily Driver and autoX
1966 Chevelle MALIBU ( mine since 1971) Drag car converting to a track car!
Old 04-11-2008, 06:02 AM
ProTouring442's Avatar
You must have had better luck than me! Seamless is not the term I would use, that sucker clacks and clanks like crazy!
Shiny Side Up!
Bill
