Old 02-20-2008, 06:11 AM
tony69 tony69 is offline
Exclamation 69 camaro steering up grade
hello everyone,
any advise on a sterring up grade for my 69 camaro? i now have power steering from factory. my header hit the steering box, i'm putting in a new engine and don't want to crush my new header tube. also i want to to have a tighter feeling steering system. please help with this issue.
thank you
tony69
Old 02-20-2008, 08:46 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Tony,
The steering in my 67 has the AGR steering gears and it works great. Everyone that's driven the car comments on it. I haven't driven a Camaro with anything other than stock so I can't tell you about other products, but I'm very happy with the feel the AGR kit provides. http://www.agrperformance.com
Not sure about your header issue. You may want to contact AWR68. He's pretty good with that kind of info.
Good luck!
Curtis
Old 02-20-2008, 09:29 AM
NEVER ENOUGH NEVER ENOUGH is offline
There is probably alot more than you will want to know here, but it's worth reading.
http://www.camaros.net/forums/showthread.php?t=103139
This member has no signature.
Old 02-20-2008, 04:53 PM
Smittys67's Avatar
Smittys67 Smittys67 is offline
The agr or dse box are both good choices. If you change the one bolt on the inside lower corner to a button head allen it usually fixes the header issue.
Old 02-21-2008, 01:29 AM
ok guy's, thank's for the info. but the header clearance is not from the bolt but it is hitting up against the steering box housing. i have read that the lee 670 box is much smaller than the 800, is this correct? also is the lee steering box a much but box than the agr. also is the unisteer power rack a better set up than a steering box?
thanks
tony
