Old 02-21-2008, 07:00 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Using an air flange tool
If I use an air flange tool for putting in quarter patch panels, will the flange tool cause the existing quarters to warp at all? Or should I go about 6", then stop, then go again etc? Any advice would be great.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 02-21-2008, 07:16 PM
1967bigdaddy's Avatar
1967bigdaddy 1967bigdaddy is offline
Default Don't sweat it.
I just did this today.
My best advice to for you,... is to use a guidline as a reference and then follow it to the best of your ability and you should be fine.
Also remove any old paint prior to doing this. That way you get a nice clean line. No warpage issues on this end. I can get a picture of what I did if you like. Works great
