Old 02-27-2008, 07:38 PM
67ragtp 67ragtp is offline
Default Dale Jrs 67 at DSE for a sub, mech linkage Q
Im a bit confused looking at this. Can any one explain to me why DSE spaced the z bar bracket off the surface of the rails, or Is it just a function of the design of there sub. Are they all set up like this or is the z bar a longer piece? - Thanks Rich
Old 02-27-2008, 07:46 PM
highboost highboost is offline
Looks like it is there to clear the u-joint on the stearing shaft. Just my .02...
Cody
Current Project:
'00 Mustang GT - 4V Conversion
Old 02-27-2008, 08:05 PM
The frame is made to run a 275mm as well. I am sure the frame rail is closer to the middle of the car at that point.
Old 02-27-2008, 08:15 PM
Really??? That's a some interesting information. I didn't realize DSE changed the design of the frame that extensively.
Cody
Current Project:
Old 02-27-2008, 08:21 PM
I have the same frame in my car........I looked at the photos and I think it's due to a narrower frame rail.
Old 02-27-2008, 08:44 PM
jpdeuce's Avatar
jpdeuce jpdeuce is offline
Thats a stock z-bar in the stock location. I've used two of them without any problems. The frame rail at that point is just that much more narrow than stock. The stand off allows you to bolt it on with nuts from behind.
Old 02-28-2008, 04:33 AM
good info- Thanks, Im gonna assume that when you purchase the sub from DSE, it comes with the stand-off bracket already welded in place?
Thanks Rich
Old 02-28-2008, 05:13 AM
murtah's Avatar
murtah murtah is offline
That's correct. All of their subs have the bracket welded on.
Old 02-28-2008, 10:43 AM
Actually they don't. Mine does not have one. I am going to bolt on my Z Bar bracketry.
Old 02-28-2008, 08:49 PM
jpdeuce's Avatar
When you order the sub you have to specify with or w/o.
