Old 03-01-2008, 12:44 AM
ls1 nova ls1 nova is offline
Default Mod to DSE LCA
Just purchased dse speed kit II with the understanding they were not easy to adjust but did perform very well. What I would like to do is cut the bottom of the cup where the coil over mounts to.. Then have a 5/8 x 5/8 ring machined, tapped and welded to lca flush where I cut the plate from. Then bolt the shock plate to the machined ring.(using grade 8 bolts/locking nuts) This would allow you to pull the plate/shock and adjust very easy. Does any body see any negatives other than a slight weight gain to LCA. Hopefully I can talk to Kyle next week. If any body would like I can post pics tomorrow
