Old 03-01-2008, 12:52 PM
redsand redsand is offline
Default Opinions on this?
Is this too good to be true? Based on price?
http://cgi.ebay.com/ebaymotors/Chevy...spagenameZWDVW
I was thinking on putting this on my 60 impala?
THIS TURBO KIT WILL INCLUDE :
X2 T04E Turbo Charger
- T4 Flange Hybrid Turbo
- .57 Compressor Wheel Trim
- .50 Compressor, .63 Turbine
- 3" Inlet, 2" Outlet
- Reliable and well built - Potential for 30+ PSI
Stainless Steel Manifold
- Maximum Durability
- T3 Flange
- 4-2-1 Design Strong Tig Weld
- Direct Bolt on- NO Mods
Bolt On Front Mount Intercooler
Intercooler Piping
- T-bolt Clamps
- Silicone Hoses
2x 38MM Purple Wastegates
X2 Dual Stage Super Sequential Blow off Valve
Direct Bolt on Flange Pipe for Blow off Valve
X2 Oil Feed Line
X2 Red Manual Boost Controller
Includes almost all necessary parts (Gaskets, Vacuum Hoses, Vacuum Tee's, Clamps, Bolts, Nuts)
DOES NOT INCLUDE: TURBO OIL RETURN LINE AND OIL PAN FITTING
ECU UPGRADE AND TUNING IS REQUIRED!!!
RECOMMENDATIONS FOR HIGH BOOST SET-UPS - larger injectors, fuel pump, adjustable cam gears, catback exhaust system, spark plugs, etc.
Old 03-01-2008, 01:22 PM
badmatt's Avatar
badmatt badmatt is offline
wouldnt touch it with a 10 foot pole!
Old 03-01-2008, 02:37 PM
surreyboy
Guest
Posts: n/a
i wouldnt use it.
Old 03-01-2008, 03:30 PM
BLACKJACK's Avatar
BLACKJACK BLACKJACK is offline
Thumbs down NOOOOooooo!!
DON'T DEW IT CHEAP STUFF!!!
"SUNOCO TWIST"FRED https://www.youtube.com/watch?v=YfpTBwibHCc
Old 03-01-2008, 07:25 PM
Default Appreciate
I appreciate the advice.
