Old 03-08-2008, 02:53 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default DSE tubs and framerails question
If I was to use the DSE deep tubs in 68 Nova, will they fit without notching the frame rails? I have new wheel houses, but if it will save me the time of cutting and adding in a strip, I would be better off going with the DSE. Thanks.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 03-08-2008, 07:23 PM
Rick D's Avatar
Rick D Rick D is offline
No they will not fit without notching the frame rails and cutting out the upper shock mounts. I just finishes mini tubing a 69 nova here are some pictures of it. The tub pic are at the end.
https://lateral-g.net/forums/showthread.php4?t=5437
Rick
Old 03-09-2008, 01:48 PM
scherp69's Avatar
I thought I might have to. Thanks.
Mike
New Gen Splitters
LS3 and TKO600
