Old 03-16-2008, 04:22 PM
mousetang's Avatar
mousetang mousetang is offline
Default turbo inlet tubing, aluminum or stainless which one & why?
I am planning on building my own twin turbo system for an 07' mustang, the turbos are going to be mid-mounted under the rear seat where the factory gas tank is now, should be a killer hidden system if all goes well. Was wanting input from those that have built their own or builds custom systems as which tubing is better to use and why?
D-Rail
07 gt 76mm huffer 3.55 gears=quick gear changes!
04 duramax edge/exhaust/intake=lots of black smoke!
70 c-10 350/350/3.73=high gas prices!
Old 03-16-2008, 04:50 PM
deuce_454's Avatar
Ive only ever used stainless for that kind... super easy to tig weld, and looks nice even when exposed to the elements, but its heavier, and conducts less heats... guess if my tig was AC/DC id use it
Jake: Hit it.
Old 03-16-2008, 05:31 PM
mousetang's Avatar
thanks for the reply deuce454, every bit of info is much appreciated
D-Rail
Old 03-16-2008, 11:50 PM
Check from ebay. There are few "ebay shops" wich sell aluminium tubing,hoses, clamps everything you need.
63 Z06
Old 03-17-2008, 02:04 PM
1Bad'66's Avatar
1Bad'66 1Bad'66 is offline
I like aluminum. It's lighter, and also will conduct heat a little better than the stainless---maybe keeping your inlet temps a little cooler: I don't know how much this really helps, but in theory, I like it!
Now for the stainless, yes, easy to weld, holds up better, polishes up great (and stays that way).
Your choice 'bro. Let us know what ya decide, and keep us posted on your project.
Later,
1966 SS Chevy II/Nova, F1 Procharged roller 408, Chassisworks front end, mini tubbed, etc, etc, etc...
Proudly sponsored by Adam's Polishes. www.adamspolishes.com
Car is for sale!!!
"If it ain't got that whistle, it ain't a missle!!!
